Question about Irons
Rowenta steamium all lights on - Irons
Rowenta DW9080 Auto/Off stuck. How do I bypass the Auto/Off feature, or find a replacement switch?
thermostat defective,,,can be do drect by expert professional,,,but it will burn your all clothes due to very hot position,without auto cut
Nov 13, 2014 | Rowenta DW9080 Steamium 1800-Watt Steam...
Heat goes off and red light blinks
Contact Rowenta if the yellow and red LED lights start to blink; this indicates an internal electrical failure.
There are over 200 complaints on the consumer affairs website, that include same this problem.
Its better to be safe than sorry.
Apr 24, 2014 | Rowenta Irons
Rowenta dw9070 manual is lost
The Rowenta dw9070 manual is lost by the Company? Can't they find an owner that would send them a copy of it?
Apr 16, 2014 | Rowenta Irons
Will not heat
iron will not heat if we put the level is quit low
Sep 22, 2012 | Rowenta Steamium Advancer Iron
Rowenta Pro Steamer only works 5 minutes then shuts off!
temp limit switch bad... replace iron(sorry)
Jul 04, 2012 | Rowenta Irons
I own a Rowenta Steamium DW9080 steam iron. I need a replacement plastic door for the water reservoir. The iron is functional and I do not feel it necessary to purchase the entire handle and cord...
Not familiar with that newer model, but here is the local dealer who is most helpful in California:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Aug 29, 2011 | Rowenta DG-980 Iron
Lights come on but it don't heat up..
Sounds like a defective thermofuse. Rowenta doesn't encourage anyone to repair their product except their authorized service centers. Parts are not made available. Go to rowenta.com to find the nearest service center and call them.
Nov 07, 2010 | Rowenta DZ9080 Iron with Auto Shut-off
Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
Sep 18, 2008 | Rowenta Effective DX1700 Iron with Auto...
Rowenta powerglide 2
Rowenta DE-09 will not turn on. Plug it in and nothing happens. Is a fuse blown or some problem similar to that happening? Thanks
Chirs
3324747@gmail.com
Jul 08, 2008 | Rowenta DE09 Iron with Auto Shut-off
Irons Logo
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
