Question about Exercise & Fitness
Accusplit health engine KS10
Need to replace battery
I changed the new batteries but still digital display is not shown
if the batteries are new and the battery terminals are clean and not corroded or broken, and the battery polarity is correct when they were installed. There must be a fault in the internal circuits of the scale, and a technician with the right tools, training, and experience will be needed to repair it.
Maybe time for a new scale.
Oct 05, 2017 | Health-O-Meter Health o Meter BFM681DQ-63...
I have a 140S accusplit eagle digiwalker but no instructions. How do I begin to use it??
go to google and type in 140s accusplit eagle and you will get a lot of answers. It would take me forever to type it here and as you are obviously able to use a compute,r the solution I suggest will be your best bet :-)
Mar 06, 2012 | Cars & Trucks
I have an accusplit pro survivor 601X and need the instruction booklet for the settings and functions
1) How to find manuals for electronic products:
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
2) Accusplit does not seem to have manuals (fortunately they have a catalog to buy from)
Searching accusplit does not show pro survivor or 601X
But they have a contact number
Contact accusplit
Oct 08, 2010 | Accusplit 740MXT Timer
Hiiiiiiiii......my hp dv6-2165tx battery does not charge properly.......when i plugged in it shows charging but after some time it shows not charging &plugged in.........why
You may need to diagnose the status of your battery.
Press control+Shift+Delete to do so. Make sure it is plugged in.
If it reports the health is good, then it is the heat sink responsible for the problem. Get your laptop serviced at the service centre.
If it says primary battery not detected and health 'Replace', your battery may be old enough to be replaced.
If the battery backup has reduced drastically within past few days, then you need to get the battery replaced.
your battery may be covered in your HP warranty.
One thing you need to know is that, plugged in & not charging is a safety step taken by HP to ensure that your computer doesn't get overheated. So, you don't need to worry much unless it is persistant.
Again, kindly use your laptop while keeping it on a hard surface so that the processor fan & exhaust doesn't get blocked.
Reagards.
Jun 30, 2010 | Computers & Internet
Battery died, replaced altenator, got new battery, battery still dieing
Since you replaced both the alternator and the battery, it should be working and the first thing to check is for loose and corroded connections.
In any case, this is what you should do to check the health of your car charging system with the assistance of a good (no need for an expensive unit) digital multimiter:
1) With the car engine not running and ignition off, measure the voltage across the battery: it should read around 12.8 Volts and anything below 10.5 Volts would indicate a faulty battery with possibly one or more shorted cell.
2) With engine running and idling, measure the voltage around the battery terminal: it should read around 13.8 Volts and any thing below 13.5 Volts or much above 13.8 will indicate a faulty alternator OR alterntor regulator.
3) Repeat step two by gently reving the engine: the correct 13.8 Volts should be maintained even with car light on.
Hope it helps: let me know how you go!
Apr 24, 2010 | 1999 Toyota Avalon
PEDOMETER
I am sure there is a user manual to download but did not found anything with google...
If search engines are of no help, just ask some deep web specialists, e.g.
http://manualfox.com - if they don´t find it, it does not exist in the Internet.
Oct 21, 2009 | Sport & Outdoor - Others
Health o meter-HDM562DQ-18, replaced battery, want to reset, no instructions.Help!
just inside the battery compartment, where the battery door latch goes, its about 3/4 on an inch down.
Jun 29, 2009 | Health-O-Meter Health O Meter HDM520KD 18...
Exercise & Fitness Logo
27 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
