Question about Freezers
LEVELING FREEZER - Freezers
  • 10,865 Answers
It is important to level the freezer. To do so you will need level, generally a 12 inch or 24 inch available at any hardware store.
The legs generally unscrew from under the unit to help in leveling. sometimes, depending upon how unlevel the floor is you may need to use blocks of lumber to level it up.
Posted on Jun 20, 2009
I have problem turning leveling legs on upright Danby freezer
Get a block,then lift freezer and push block under with foot,then get a pair of plyers and turn legs,or get a 2x4 and do front,then back.get a leveler to see if it's level.
Aug 26, 2016 | Danby Freezers
How do I level my domestic kelvinator fridge . the floor seems to be level . I recently relocated to Cairns
the front feet under the door opening are adjustable screws. You may have to use a shifter to get them to move as they mat be rusted . adjust so the fridge slopes slightly to the rear. This keeps any moisture on the back wall to drain out the hole and the door will close if left open
Mar 03, 2015 | Kelvinator 12 cu. ft. / 340 liter Chest...
Frigidaire upright freezer door will not seal
Hi Chris, this is AP! Thank you for your post.
I understand you are having trouble with the door sealing on your upright freezer. Many times this can be caused by the freezer not being leveled. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems. To level your upright freezer use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, 1/2 bubble higher, so that the door closes easily when left halfway open. I hope this information has been helpful.
Mar 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
We just purchashed a Frgidaire Freezer model #LFFH21F7HWG. Does it have leveling legs on the back as well as the front? Are we missing 2 leveling legs?
usually the back wheels are rollers that allow you to pull the fridge straight out from the wall, so NO, not leveling in the back, but you don't need it anyway, just use the front adjustments
Mar 17, 2011 | Frigidaire 20.6 cu. ft. / 583 liter...
Need to change the leveling on an already loaded freezer . Is the bottom front panel a way in?
It's HEAVY --BUT it has to be raised at the front somehow (understructure may bend if not careful)--then nut adjustment loosened & adjust.
Feb 07, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Door on new Kenmore freezer hard to open ... could this be a leveling problem? I wouldn't think it is an ice build-up problem since the freezer was only installed last Friday (9/24) and the ice maker is...
Check thoroughly for any obstructions, shipping tape, remaining pieces of plastic, in and around the doors, door frame, cabinet frame that the door contacts when closed, and around the upper and lower hinges. Do you hear any noises when opening or closing the door? Do you see the door rubbing on the inside liner as you open or close the door? Were the doors removed and replaced in moving? This last one, if it is the case, check the alignment at the upper hinges, loosen but dont remove the screws, and adjust the door away from center.
Sep 30, 2010 | Freezers
I have the same problem
Most probably defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer. This can also be caused by the drain hole being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost.
Aug 24, 2009 | Freezers
Shutting down fridge/freezer when moving house
Other than un-hooking the power and any other connection like water, then defrosting to get rid of any ice buildup then prep for moving...the only thing you have to be aware of is transporting it in an unright position to protect the condenser. Here are the steps:
1. Remove all food from the refrigerator and pack all
frozen food in dry ice.
2. Depending on your model, turn the thermostat control
(refrigerator control) to OFF. See the Setting the
Controls section.
3. Unplug the refrigerator.
4. Clean, wipe and dry thoroughly.
5. Take out all removable parts, wrap them well and tape
them together so they don’t shift and rattle during the
move.
6. Depending on the model, raise the front of the
refrigerator so it rolls more easily OR screw in the
leveling legs all the way so they don’t scrape the floor.
See the Door Closing section.
7. Tape the doors shut and tape the power cord to the
refrigerator cabinet.
Apr 24, 2009 | Freezers
Sides of freezer extremely hot
if there is air getting into the freezer because the door is not sealing properly the unit will run because it is sensing it is not cold enough inside. your unit releses the heat from the refrigerant through copper tubing that runs through the cabinet, and thats why it is hot. you need to level the unit make sure the door is sealing on the top bottom and both sides ansd then the freezer will work properly and be able to shut off after it has come down to the proper temp.
Aug 05, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
111 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
