Question about Toro Garden
Brakes froze up on toro timecutter ss4235
I tried to release the emergency brake that operates from the brake module by hand. It movs but when I start it up it brakes on again and won't move?
  • 46 Answers
SOURCE: rear brakes locking up with slight touch of brake pedal.
Most of the time with the rear brakes locking up the brake drums are warpped. If you remove the rear brake drums and take them to almost any auto parts store (Napa, Checkers ect.) they will turn the drums for about $10 a piece.
After you have the drums turned you will need to readjust the rear brakes.
Posted on Aug 29, 2008
  • 393 Answers
SOURCE: 2000 isuzu rodeo brake problems
your master cylinder is gone. when stopped apply pedal and hold let up slightly then reapply if pedal sinks to floor master is bad.
Posted on Nov 16, 2008
tripletauto
  • 1450 Answers
SOURCE: On my 2003 Chevy Suburban, the emergency brake won't release.
there is a cable running from handle to brake assembly it is probably broke there is a release lever under there on brake about a one inch lever hold down on brake and move this and let up on pedal.
Posted on Nov 20, 2008
  • 68 Answers
SOURCE: Emergency brake stuck, pedal release broken
What happens is the brake cables rust inside the cable sheath and then they won't slide easily. There's no good fix for this other than replacement. It's not easy to even find where they are stuck.It might be possible to find the end of the cables at the back wheels and pull the cables back---to release the tension
Posted on Apr 26, 2009
  • 246 Answers
SOURCE: bought a 2002 toro timecutter 18-52 zero turn lawn
Hello:
>>You can View a Breakdown/IPL of the Mower at this Site Addy, https://lookup3.toro.com/partdex/default.cfm and Select Start Parts Viewer. Now Enter the Model Numbers () and Click Search. Now Select View Assembly Drawings for your Year Model.
At the Bottom of the Page (#6), Use this Link to Locate your Local Toro Dealer who can Order the Manual for you or you can Contact Toro Using the Options at this Site Addy; http://www.toro.com/contact/Homeowner.html .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
Can the toro timecutter ss4235 bagger stay on when using the trailer hitch?
Simple answer herei "No" the trailer hitch gets in the way of the bag holder system sorry I know of no adaptations either
May 21, 2016 | Toro Garden
Toro wont start
Clean the fins on top of motor and engine.
Sep 07, 2014 | Toro TimeCutter SS4235 - 20HP 42 Zero Turn...
Toro ss4235 release brake stalls when arm pushed in
bad check valve or buy pass screen dirty take to shop 100.00 for by pass to fix 100.00 for check valve to fix
Sep 03, 2014 | Toro Garden
How do i unlock brake tried resetting arms stalls when engaging handles also wont come out of gear when releasing bypass valve
you most likely have a module behind your battery... it's either bad or corrosion has taken it's toll and you will also need a wire harness ... and yes, when those go bad, you can't even move those things...
Sep 03, 2014 | Toro Mowers - Time Cutter SS4235 42""...
Toro ss4235 wont go into gear nor bypass valves wont take it out of gear
try forcing the wheel to move get the ztr rear off the ground and try turning the wheel if dont but pump sqeeled you have a bad check valve or pump is going out i say bad check vale rebuild it
Sep 03, 2014 | Toro TimeCutter SS4235 - 20HP 42 Zero Turn...
Toro instructions
un hook them they maybe dirty and rust causeing no release
Sep 01, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
Timecutter 42 kholer electrical problem
The battery may not be chargeable and will have to be replaced.
Apr 20, 2014 | Simplicity 42 Toro Timecutter 20hp Kohler...
Time cutter hydro does not move but i can hear it whine
Did you check the could have air in the system, did you check the hydro oil level? In my experience with toro hydro systems is when i change the oil air gets in the system. At low rpm move control handles forward and reverse several times until air works itself out. if this doesn't work more than likely there could be internal pump problems.
Sep 02, 2013 | Toro Riding Lawn Mower. TimeCutter SS4235...
Toro cutting off
Maybe low oil level, all mowers have a low oil cutoff. 30w oil.
Aug 07, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Garden Logo
29 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
