Question about Garment Steamers & Presses
Garment steamer smells like cord is burning - Garment Steamers & Presses
My steamer is no longer producing steam, how do I fix?
To troubleshoot something like this.
1. make sure it's plugged and the outlet is working.
2. Is it getting hot? If not, either the heating element is burned out or not getting power.
3. If it is getting hot check the steam ports for calcium build up (run straight vinegar through it)
Jul 14, 2014 | Garment Steamers & Presses
Home touch garment steamer model ps-280 wont turn on
If it were left on its possible that the element that heats the water has burned out think blown light bulb have your Mr Test it with a ohm meter to see if the circuit is open
May 02, 2014 | Garment Steamers & Presses
Where can I get parts for the Yamata PSS-2001? I only need casters.
Best way is to contact manufacture for part information and part dealer near your location
Dec 10, 2013 | Yamata Ricoma PSS-2001 PSS-980 Garment...
Home Touch PS 250B
Best way is to contact manufacture and ask for part dealer near your location
Nov 17, 2013 | Homedics Home Touch Commercial Garment...
I " inherited" this iron without a manual. How do I retract the cord on my cordless iron? It refers to a button but I can't locate it.
I never saw an iron with a retractable cord . The cover would have to be large enough to accomodate the cord and the heat from the iron could melt the cord. Are you sure it supposed to work like that?
Sep 24, 2013 | Panasonic Appliances Steam Iron with Spray
My hand held little steamer will not get hot. switch comes on, but that is all it does
If the switch isworking then the only possible fact is that the heating element has failed and it might be too costly for a change.
Jun 10, 2013 | Ingenious Designs, Llc My Little Steamer...
What are the advantages of using a steamer over an iron?
steamers are usually believed to be easier to use and less damaging to the fabric over time
Jan 30, 2013 | Garment Steamers & Presses
Garment Steamers & Presses Logo
188 people viewed this question
Top Garment Steamers & Presses Experts
Tom Chichester
ray gallant
Are you a Garment Steamer and Press Expert? Answer questions, earn points and help others
