Washing machine wont spin
I have had this machine for 6 years with no problem. It is now coming up with E1 when it gets to the spin part of the cycle. This error is for "draining too slow." I disconnected & reconnected the drainage hose & it is not blocked. The water will drain & machine will spin if I lower the drainage hose to a bucket on the floor. I may not have reconnected the hose at the right angle. I have put it with the bend on the side facing which to the trough.
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
  • 30 Answers
SOURCE: my washing machine wont drain the water
Sounds like a blocked pump.The pump could be burnt out.
Posted on Aug 03, 2008
SOURCE: Washer leaking water from bottom
MIne did and it was the bleach container on the top that was getting clogged and leaking over, we actually drilled the hole a bit bigger and cleaned it all out and it stopped. I've had to take the whole top of the washer off to do this about 2-3 times now.
Posted on Dec 26, 2008
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
SOURCE: Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Door locked light flashes.
After turning off at power point, then restarting unit will commence but light starts flashing again and machine stops
Posted on Jul 04, 2010
Have you checked the lid safety switch? Even if it doesn't spin, the cycle timer will continue.
Nov 16, 2013 | Washing Machines
Neptune washer mah3000aww skips to spin cycle and wont drain
It sounds like the "repaired" main control board is still the issue with it being intermittent.
Nov 20, 2012 | Maytag Neptune Washer
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Apr 21, 2011 | GE Washing Machines
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Blows 6 amp fuse in top panel. On spin cycle runs the pump but motor wont rotate for spin. If left blows fuse again.
Remove the hoses and check the impeller of the pump for an obstruction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Washing Machines
Kenmoore washing machine no longer spins during normal wash cycles
sounds like your spin cycle belt has come off or broken. it,s a simple fix at a repair shop.
May 02, 2009 | Washing Machines
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire front loader
Can you hear the motor running? If so it will be the belt. If not simple could be the wiring..connection at the motor or broken wire. Brush's..very common at about 4-6 years depending on usage. or the controller.
Jan 03, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
