Question about JVC AV-56P575 56" Rear Projection HDTV-Ready Television
Lost remote can't scan
We have dish and can't scan so the tv sets up
I have lost my dish set remote so how i can change the channels on the tv.i have tv remote.
if you lost your remote control for the dish simple call the customer service and asked for a new remote control. there are no ways to program a regular remote to a dish receiver box.
Feb 07, 2014 | DISH Network Televison & Video
My remote will not turn the tv on or adjust the sound, it will change channels
First, try pressing TV on the remote, check if that solves the problem. Then press Sat and try the TV power button again. If the remote previously controlled the TV, you lost the code for the TV. If you have your Dish Network manual, check if you wrote down the code when it was originally programmed. Which specific remote/receiver do you have? The programming directions and code lists are available here: http://www.dishnetwork.com/supportsection/remote-setup . You can also scan all of the codes to find the correct one: see http://www.dishnetwork.com/SupportSection/power-scan-instructions . Additional remote/receiver manuals are here: http://www.dishnetwork.com/SupportSection/manuals .
The direct coding procedure for the Dish remote that I have is: while facing the TV to be controlled (after adjusting the key for TV1/TV2 in a multiple TV system), press and hold TV until all four indicators light up. Then enter the 3 digit code. Press and release the # key. Then see if the code TV powers off when you press Power. Then press Sat and check if the TV power button works. Try additional codes if the TV doesn't respond.
If you recently got a new TV and you tried to program the remote for your TV, your dish remote may not have the code you need. (Most universal remotes are limited to codes for devices released 6 months or more before the remote was programmed.) In that case, you should use the TV remote (and see if it has an option to control the satellite receiver). Alternatively, get a new universal remote that will control all of your devices. (The remotes that can be programmed by USB are the easiest to set up.)
I hope this helps.
Jul 09, 2011 | DISH Network IR Remote Control
My Dish 5.3 remote no longer turns my TV on/off, nor does it control volume. All other aspects are fine.
Hi christinehacmy name is Mike Houston of DISH Network and I was reading over your post andthe remote has lost the code for your TV. There is a step called Power Scan forthe DISH Network remote, I will send a link that will help with these steps. http://www.dishnetwork.com/SupportSection/power-scan-instructions
Feb 14, 2011 | DISH Network Ir To Uhf Dish Network Remote...
Need free help. How do I program a dish network remote to operate my sanyo DP19648 tv? I lost the code sheet.
I hope that this has been resolved, but if not, here are some simple steps to help you out. The link below will walk you through a power scan. The power scan scans through the codes on the tv until it reaches the correct one.
Power scan:
Here is another link to the codes for each brand of tv. You will need to follow these steps:
1.Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3-digit code
3. Press the Pound (#) button below the number 9 on the numeric keypad
4. Try to power the tv off/on, and try the volume. If one or all of these do not work, proceed back to step 1 with a different code.
5. Once all functions work, press the SAT button on your remote, and you are all set
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Becki Barned
DISH Network Customer Service
Sep 21, 2010 | Sanyo DP19648 19 in. LCD TV
Dish Network remote will not turn the set on or off and will not adjust the sound level. Dish tells the they do not have the code For Element TV's and I will have to use 2 remotes. Can you solve this...
Sometimes the remotes have a hard time programming to the tv. Below is the link to the steps for a power scan. Instead of needing a code to program the remote, the remote will scan through the codes on the tv until it reaches the one that works. I hope that this helps!!!!
Becki Barned
Sep 16, 2010 | Element Electronics FLX1911B 19 in. LCD TV
Recently moved to another city, lost the remote and can't find the code to program the DISH Network remote to get my tv off channel A 4
Hi my nameis Mike Houston of DISH Network and I was going over your post and see youmoved and lost the remote. We have what we call a Power Scan for the DISHNetwork remote; it will allow you to get the code to the TV. http://www.dishnetwork.com/SupportSection/power-scan-instructions
Aug 28, 2010 | Initial HDTV-320 32 in. LCD TV
Remote tv on & off won't work
I do hope that this has been resolved. If not, I have enclosed some steps for you to follow. You will want to follow the link below, which will walk you through a power scan. A power scan will scan your tv for the code that works with the remote. I hope that this helps.
Becki Barned
Jul 27, 2010 | DISH Network IR Remote Control
Dish network tv code for Nikada LA1421
Hello cobra_vmg, my name is Michael Hurst with DISH Network. I have looked through all of the remote codes for the maker and mode of your TV and we don't have a set code for your TV. You can try a Power Scan and see if there is a code for your TV. If the Power Scan doesn't work then our remote isn't compatible with your TV. Here is how you would do a Power Scan:
Mar 31, 2010 | DISH Network IR Remote Control
Dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
Nov 23, 2008 | DISH Network IR Remote Control
JVC AV-56P575 56" Rear Projection HDTV-Ready Television Logo
12 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
