Question about Bosch Nexxt 500 Dryer
Bosch next 500 series dryer won't heat up
The heating element does not seem to be working
SOURCE: My Bosch Condensation dryer (W2L 5400) won't heat up -- can't find the reset button
you need to remove the centre metal plate,after powering off the dryer. The small red reset button is on one of the black plactic connects on my model (WTA4408)
Posted on Jun 04, 2008
AlmostBob
  • 550 Answers
SOURCE: bosch nexxt 3300 dryer not heating
with the dryer unplugged 220v is not fun
with a meter, and first disconnecting cables to each component and reconnecting them after the test is complete
check the continuity of the element, it may have burned out
check continuity of the thermostats on the heater housing and fan housing,
check the interior of the fan body for sox and lint
not a solution, yet
Posted on Oct 18, 2008
SOURCE: Bosch nexxt 500 series dryer
I had the same trouble after moving to a new house, I first thought I had a voltage problem. It turns out that the heating coil has a high temp re-setable switch in side the back - lower right side. the sencor has 2 screws, I took it out and cleaned off the lint and now have dryed 5 loads with 0 issues. looks like a flaw in design that would allow lint to get in the heating coils!!!!! I think I'm going to look for a new dryer before I burn down the house!!
Posted on Dec 28, 2009
SOURCE: Bosch Condenser Dryer Classixx
I found this on justanswer.com, I am going to try it this weekend and I will post an update.
"Ok if you remove the left hand side panel then located at the back is the drain pump
remove the hose on it which goes up to the bottle and blow up it to make sure its clear.
If thats fine then remove the pump and clear any fluff thats in there and make sure the impeller is ok and turning fine.
Then refit and try again hopefully this should sort it out.
let me know if you need anymore info."
Posted on Jan 02, 2010
heatman101
  • 43501 Answers
SOURCE: Bosch nexxt 500 plus dryer does not heat up. I
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 28, 2010
My Bosch Nexxt 500 dryer stopped heating. All other functions work fine except heat. I've checked continuity on heating element & overtemp breaker- both OK. What else could be the problem? Fuse?
CONSIDER THIS
BOTH LEGS OF AC MUST WORK TO GET HEAT FOR DRYER
Maybe you don''t have power to both legs of your receptacle. Both legs of the 220 volt AC have to work go get heat. Only one leg is used to run the motor etc.. Your motor runs so this can fool you into believing that the electrical connection is ok when it really is not. Your dryer is on a double circuit with two breakers. If one fails you lose one 110 volt leg which can be the one giving the full 220 Volt needed for the heater. This happens quite frequently and people mistakenly replace heating coils. You could have a bad breaker, one of the two. You must check this first before assuming anything else. Get help if you are uncomfortable with potentially deadly voltages
Dec 14, 2015 | Bosch Nexxt 500 Dryer
I have a Bosch nexxt 500 series dryer. The heating element wouldn't heat. I took it apart cleaned it put it back together and now all it will do is click
Make sure you have returned all wiring back to correct positions and that the drive belt has been refitted correctly.
Feb 28, 2015 | Bosch Dryers
Why does my bosch dryer not drying my clothes
will need to check the fuse thermostats also before buying new heating element, the thermal cut off may be bad, the cycling switch, the hi-lo thermostat u can test the heating element with a multimeter for continuity etc?
Dec 18, 2014 | Bosch 500 Plus Series Nexxt Clothes Dryer...
Error code list
What does the error code 0.20 mean on Bosch next 500 series dryer wtmc 8702 U.S./031fd 3321. The heating element was checked and deemed ok
Jul 03, 2014 | Bosch Dishwashers
I have a Bosch Nexxt 500 series dryer. It runs but has no heat. I have cleaned the exhaust system thoroughly and cleaned the heat sensor. Now I think the problem may be in the heating element? Is this a...
probably not the heating element but one of the toc's has gone(temperature overload cut out)if you are handy with a multimeter test it and if it shows the symbol 'ol' youll know which one is gone
Aug 18, 2013 | Bosch Dryers
Bosch nexxt 500 elec dryer has no heat to it
There is a switch located on the duct from the heating element. Which you are not able to reset, you have to replace it if it's defective. Do a continuity test on it and if there is no continuity then the switch has to be replaced.
Jan 04, 2012 | Bosch Nexxt 500 Dryer
Bosch nexxt 500 series electric dryer will not heat up, it just blows cold air. I have removed the back panel and pressed the reset button-nothing changed it still won't heat. The dryer had been in...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 16, 2011 | Bosch Dryers
Bosch nexxt 500 series dryer runs but stopped heating blows cold air and tumbles but just have no heat.
The heater element has failed,if electric dryer,. The element should be accessed at the rear panel.
If Gas heater...same but gas burner has failed to ignite.
Hope thes helps you
This help is free...Please find time to rate me.
Jun 28, 2011 | Dryers
I have a Bosch nextt 500 series dryer and after 2 years of use the problem I have is the heat will shut off and the dryer will keep running and I have to press the reset button on the backside of the dryer
Open the front panel, remove heat exchanger and clean. also clean out lint tray. this might help a little. Now lets check if the thermal sensor or heating element needs to be replaced.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button. To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the thermal sensor. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Feb 01, 2011 | Bosch Axxis WTL 5410 Electric Dryer
Open Questions:
See all Bosch Nexxt 500 Dryer Questions
Bosch Nexxt 500 Dryer Logo
69 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
