Question about LG Heating & Cooling
Ch02 error at lg multi v evaporator - LG Heating & Cooling
4 Suggested Answers
SOURCE: Get a CH02 error. Can't get service. No response.
i have the lg lp120hed units as well. i had a unit give me ch02 error a while back i replaced the unit with a spare....now the spare is not working either.
looking at the manual, ch02 error means "indoor coil thermistor error"....calling lg for that part now.
good luck.
Posted on Jun 03, 2010
hvac1960
  • 2133 Answers
SOURCE: How to fix LG CH02
Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5
kOhm at 25C. If not replace sensor
Posted on Jan 16, 2011
hvac1960
  • 2133 Answers
SOURCE: Hi my LG healthplus inverter
Posted on Jan 20, 2011
Over ride ch02
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Air Conditioning Coral Springs
May 24, 2014 | LG Heating & Cooling
Why is unit flashing ch02 code?
May 23, 2014 | LG LSN240HSV LSU240HSV 24,000 BTU 18.9...
Lg digital air cond show ch02 display
02 fault according to LG bible means that the indoor pipe sensor has failed. You will need to obtain a new sensor or get a Tech to supply and fit. The indoor unit needs to be accessed (Opened up) to repair this.
Dec 25, 2013 | Heating & Cooling
Hi my LG healthplus inverter system split unit keep giving me a CH02 error code. how can i solve?
Jan 20, 2011 | LG Heating & Cooling
How to fix LG CH02 error
Jan 16, 2011 | LG Heating & Cooling
What is the error codes
You should post your error code instead of asking for all of them to make it easier to respond.
I know CH02 is the temperature sensor and CH06 is the inside coil temperature sensor.
Oct 07, 2010 | LG LS-L1210CL Mini Split Air Conditioner
LG air condotioner with a CH5 error code
CH-05-Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Jul 27, 2010 | LG L1004R Air Conditioner
good luck.
Apr 01, 2010 | LG LP120HED Wall/Window Air Conditioner
LG 3phase ducted CH02 fault (internal pipe thermistor error)- every day. When it comes up the air con shuts off, and takes a few hours to clear itself. Very annoying. I notice though it comes up less if i...
have u checked your low pressure and high pressure when compressor is on. Remember the compressor has a thermal protection switch if the compressor has too much freon the A.C will work for a while turn off, then turn then off and on. Are the air filters for the evaporator clean, is the blower fan blowing the correct way. How long ago did the evaporator coil got cleaned. With a properly cleaned filter and evaporator coil you can now check for pressures. Use your ammeter and check how much the compressor is pulling and compared it to the name plate. How much tons your A.C. If you give me how much tons and low and high readings I might help you diagnose the problem. Make sure the evaporator is clean blower blowing correct way condenser cleaned and condenser fan rotating the correct way
Jul 24, 2009 | Heating & Cooling
Heating & Cooling Logo
19 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
