Question about Saitek Flight Controller Manual & Programming Guide X36 X36f X35t
Hooking up an x35f/x35t to a ps3 - Saitek Flight Controller Manual & Programming Guide X36 X36f X35t
Cant hook up my ps3 to my netgear wgr614 n150
need to get ps3 component cable that can hook directly to the router,if it is a wireless router goto ps3 setup menu,then turn on network discovery on ps3,then will ask for password from router fill password in,it will hook up.
Dec 21, 2012 | NetGear WGR614 Wireless Router
Hi, I hooked up a ps3 to my Daewoo DTQ-27U4SC tv and it wouldn't work. From what I understand, all I do is hook up the power to the ps3 and hook up the RCA cables between the ps3 and tv. I hooked up...
if the ps3 is set to hdmi it will not work threw the av cables. you need to change the settings on the ps3 to use av cable. its mostly set to hdmi as factory setup .
Jun 22, 2017 | Daewoo DTQ-27U4SC 27" TV
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
How to hook up my new PS3 to proscan HDTV. the new 80GB Sony PS3,
You will want to hook it up with a good HDMI cable and then go to that input on your tv when using the ps3
Sep 19, 2009 | Proscan Televison & Video
PS3 Video Connection--Lines on TV
this may be due to the fact that your ps3 will be set up to hd. go into video settings when you switch it on and this should solve the problem. i had similar problems and bought a hdtv until someone pointed this out to me. however once you have experienced ps3 in hd you will not go back!!! hope this helps
Jan 13, 2009 | Sony Playstation 3 (PS3) Console
Ps3
hook up usb for controler into ps3 then controller then hit ps button also use cords ps3 came with first with back power on but on stand by hold power button down for 10sec this should connect the controler to system as well as give you picture if it dosent check your tv with another device such as dvd player make sure the hook ups work
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
Help
You can't. For wireless connection on the PS3 you need to have a wireless router hooked up to your modem. Once you have your wireless network hooked up with your PC. You can give your PS3 access and the PS3 will scan for any available wireless networks. Google will help you more if you need more detail on how to set up your PS3 wirelessly.
Sep 10, 2008 | Sony Playstation 3 (PS3) Console
I need help with my ps3
did you hook the ethernet cable from the modem to mthe back of your ps3(wire internet)
do you have a wireless router(wireless internet)
are you trying to hook it up wire or wireless
Feb 19, 2008 | Sony Playstation 3 (PS3) Console
Hooking up playstation 3 to tv
you need a ps3 scart lead. i think the one of the ps2 is the same but check. it should just hook up like a ps2. if you are having any problems with the picture hold down the power button when you start up the ps3 for 10 seconds this runs the optimal screen settings for the cable you are using. but if it is the first time you are using the ps3 it will auto start in set up mode. hope this helps
Jan 09, 2008 | Sony Playstation 3 (PS3) Console
Hooking up my new PS3 to my five year old 55" Mitsubishi HDTV.
The Sony outputs 180P, not 1080i. There is a difference. I don't know what exactly, but Sony says 1080p is for superior.
Dec 31, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Saitek Flight Controller Manual & Programming Guide X36 X36f X35t Logo
35 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Hjalmer Lamminen
Hjalmer Lamminen
Rob Emerson
Rob Emerson
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
