Question about H20 Bolt Flash 4G USB
Why do i get lots buffer on internet - H20 Bolt Flash 4G USB
We are getting buffering when we are trying to watch news. We have high speed internet
I've found that many of the news channels have ads that us a lot of bandwidth and a lot of CPU. One method I've tried was to use an Ad Blocker to stop the ads and allow me to see the content without ads. My friends seem to like AdBlock Plus. Adblock Plus Surf the web without annoying ads
Dec 05, 2017 | Internet Computers & Internet
How do you buffer movies so it doesn t stop every 2-3 seconds
Usually buffering occurs when your internet provider cannot keep up with the streaming speed. If the connection to the internet is via a hard wired LAN cable, the problem may be because of a lot of traffic.
First solution is to reboot your cable modem and router
Another cause would be that the internet pathway between your TV and the streaming source, which has many node points may not be a fast one. The usual solution is to reestablish the connection . This may involve logging out and logging back in.
If your connection to the internet is by WiFi, the usual problem is that your wireless router is not fast enough and must be replaced by an updated and faster wireless router
Apr 29, 2017 | Computers & Internet
How to stop buffering on galaxy tab 3
I assume you mean video buffering. This is usually caused by a slow internet connection. You have a galaxy tab 3 so I assume the device is not the issue. If your internet connection is improved you should see the buffering happen a lot less. Try measuring your internet connection speed on a website. Something like http://www.speedtest.net can tell you what your internet speed is. Usually you want to be at least 5 Mbps or higher download speed to see minimal buffering issues.
Oct 11, 2013 | Computers & Internet
I have a LG 47 inch Smart TV Mod No 47LM6200 TV. I connect to the TV to my Wi-Fi. My router is a new Netgear R6300. I am able to stream movies and YouTube videos to two or more laptops at the same time and...
I would try connecting a network cable to the TV and router directly. Sometimes the WiFi connection can be limited by interference or the conversion process. I personally for fixed devices use a direct physical connection and WiFi only for true mobile devices.
May 04, 2017 | Computers & Internet
Buffering in blackberry 9780
Its normal and depending a lot to your isp and internet speed.
Aug 13, 2012 | Research In Motion Unlocked Rim Blackberry...
Computer buffering
i believe that your internet conection is too slow. There-for the play back speed is going faster than your incomming speed, so you get a lot of buffering. Check into a couple of ways to speed your internet up some. Good luck!!
Jun 13, 2012 | Toshiba Satellite P35-S611 Notebook
How can i make it so that I can wacth movies on netflix it does not streamline it has to constanly buffer the movies
Streaming video , stopping and buffering is due to slow connection speed. HD movies involve loading a lot of data and hence take a lot of time to buffer. Switch to non-HD video mode and see if it streams without pauses. If that does not fully resolve the problem , you will need to go for a faster internet connection.
Sep 16, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
When I try to play a Youtube Video it stops and starts continuously....How do I fix this?
Me too! I believe there are a lot of reasons for this, but a fix may not be out there. It's called buffering. Check Internet connection speed and consistency, how many other programs are running in the backround, computer proccessor speed, MB of Ram it has. Try not to play videos in HD if you were already. Just some ideas.
Apr 01, 2010 | Microsoft Windows XP Home Edition for PC
Youtube video stops and stutters and buffers a LOT
Did you properly checked your internet connection and speed? if speed is ok then try to upgrade flash player. Hope this will help u.
Regards;
Hasan
Dec 30, 2009 | Compaq Presario 700 470024-192 Notebook
Um...Note:
Watching videos online will be dependent on your Broadband speed. If the speed slow down, you will experience a lot of buffering that affects the quality or delayed Video feed. I advise to close other programs that uses the internet so the Internet speed will not be divided while viewing videos online
Jun 16, 2009 | YouTube Videos
H20 Bolt Flash 4G USB Logo
468 people viewed this question
Top H20 Computers & Internet Experts
David Payne
David Payne
Are you a H20 Computer and Internet Expert? Answer questions, earn points and help others
