Question about John Deere Garden
Concerning a Z425 John Deere mower. When I start the mower it shuts off immediately, when I try it again the motor cranks but will not start. Any suggestions
    Champion:
  • 279 Answers
Bad/old fuel (must be less than 40 days old), water in fuel, clogged fuel filter(if equipped), oil level correct?
Posted on Jun 03, 2014
buffalonyman
  • 1865 Answers
SOURCE: John Deere L118 / 22hp Briggs stalling when it is hot
Have you replaced the fuel filter?
Posted on Aug 08, 2009
  • 246 Answers
SOURCE: I have a John Deere Riding lawn mower which starts
Hello roobar2009:
>>From your Description it Sounds like a Carburetor Problem, a Bad Fuel Filter or Bad Gas.
>>If you have Changed the Filter and the Gas and the Problem is Still happening, then
>>The Following is a Simple Way to make Sure the Engine is Getting Gas from the Carburetor to Run.
>>If the Engine Starts and Quits, then Check the Carburetor Solenoid.
>>If the Carburetor Solenoid is Good or has been Removed and the Engine will Start and Quit when the Gas is Poured into the Carburetor Throat, then Soak and Clean the Carburetor.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 17, 2009
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
  • 3600 Answers
SOURCE: John Deere hydro 185 When I try to start
You have a bad disk in the starter solenoid pull the starter and go to a shop and buy a new solenoid or flip the disk in the solenoid and sand the two contacts so that it will make contact.
Posted on Jun 12, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
JD z425 zero turn mower. Shows error code 52E.
try a new battery after checking old one for voltage
Aug 13, 2016 | John Deere Riding Lawn Mower. EZtrak Z425...
John deere will not start
Charge the battery fully, verify good contact on the battery terminals. If it won't crank, check for voltage at the starter motor while trying to crank, check battery voltage while cranking (if it drops below 9V, the battery needs to be replaced).
If it cranks but doesn't fire, make sure it has plenty of good fresh gasoline, verify that the carburetor float valve isn't sticking shut, verify that the spark plug is good and you're getting good spark while you crank.
Aug 02, 2014 | John Deere Tractor Starter 285 345 2243...
Why does the battery go dead overnight after john deere z425
Need additional information...Check to see if it is the new battery or the electrical system first........ when the battery is "up", disconnect from the system. Remove both wires from the battery...connect the next day and see if the battery will crank the mower. I've experienced new battery's that have an internal short....Let us know whether battery or John Deere electrical system.....and we can troubleshoot from there...
Jun 16, 2014 | John Deere Eztrak Special Edition Kit Z425...
How to replace coil pack on John Deere Z425
Concerning a Z425 John Deere mower. When I start the mower it shuts off immediately, when I try it again the motor cranks but will not start. any suggestions?
Sep 06, 2012 | John Deere Garden
Garden Logo
159 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
