Question about Caterpillar 3406 Engine
Loss of power and engine shuts down like it starves for fuel. Put on a new pump, lines and filters, and shows no faults.
1995 chevy truck 305 engine .shuts off after a few seconds starts back up again put in gear shuts off.
At this age the pump would be a good bet. How many miles/years are on the current pump ?
Jul 30, 2015 | 1995 Chevrolet K1500
My 1987 Mercedes Benz E300 runs fine but once I put gas in it it starts sputtering and shuts off then will start hours later. Help please!
try changing the fuel filter which is next to the pump its unlikley its the pump more likley muck in the fuel line which is blocking filter starving the engine making it cut out
Apr 15, 2015 | Mercedes-Benz E-Class Cars & Trucks
When-car-reaches-2000-rpm-in-every-gear-losses-all-power
run the fault codes as a speed limiter sensor may be cutting in to protect the engine
Jan 15, 2015 | 1994 Mitsubishi Montero
Problems throttle
Fuel starved,Check fuel filter and fuel pressure. on cold engine replace the fuel filter And then stick the fuel line in a container and have helper crank the engine about 4 sec . and make sure you are getting fuel up , If not check fuel pump,. if no fix then there are more steps but add more info about truck eng fuel sys etc what i gave you is genarc to all engines Mike.
Jul 19, 2014 | 1993 Chevrolet K1500
My mower seems to have low fuel pressure. Gas filter is new, lines are clear but sometimes the engine starves for fuel. The filter has almost no gas showing in the clear globe when running. Is the black...
Yes it is a vacuum fuel pump. Remove the line to the carburetor and place a clear container to catch fuel. Crank the engine and watch to see how much fuel is being pumped. It could either be a weak fuel pump or the pickup line in the fuel tank is starting to rot, depends on how old the mower is. The pickup line in the fuel tank is rubber, and sitting in fuel for many years can break the line down causing it to fall apart. It should be noticeable more if the fuel tank is below 1/2 tank. Hope this helps, Daniel.
Jul 04, 2011 | John Deere 22HP Hydrostatic 42" Riding...
Runs good until you accelerate then it lacks power it dont miss just alarge power loss in every gear if you let off of the gas its power comes back its about to drive me crazy please help? dwb
I would suggest changing the fuel filter. The engine seems to be starving for fuel and if the filter is pulgged, the engine will bog down under load. Then the engine will run better when coasting because the fuel pressure will build up again.
Jun 21, 2009 | 2000 Ford Ranger SuperCab
1973 Corniche engine shut down
I sounds like a fuel delivery problem, I would first check the filter -above the rear axle- if it's clear, test the fuel pump delivery. ps; the original filter elements are hard to get, we usually fit a good in line unit instead, leaving the original filter housing in situ. Also, unless they are fairly new now is the time to replace the fuel hoses back there.
May 14, 2008 | 2007 Bentley Corniche
Caterpillar 3406 Engine Logo
Top Caterpillar Electrical Supplies Experts
Lawrence Oravetz
Todd Arndt
Todd Arndt
Ted Maxwell
Are you a Caterpillar Electrical Supply Expert? Answer questions, earn points and help others
