Question about Kenyon B41516 Mediterranean Series 12" Smoothtop Electric Cooktop with T
Kenyon B41516 burner is not working - Kenyon B41516 Mediterranean Series 12" Smoothtop Electric Cooktop with T
I have voltage to each side but the burners will not heat up. Indicator lite comes on and the blower comes on
Hello Gary,
Their is one of two things wrong why your surface burners are not working.
1) the block that the burners plug into it bad...it is very common for the burner block to be worn down and making very poor contact with the burners and thus their is power at the blocks and yet the burners will not work
2) the burners their self are bad
GENE
Oct 31, 2011 | Jenn-Air JED8230 Electric Cooktop
My large burner at the front does not work, yet when i replace it with\r\nthe large burner at the back it does not work , yet when you put the front burner at the back it works.
Your front burner is fine. Assuming you have an electric cooktop the problem is in the switch that controls that burner. The infinite control switch. Replace it.
Dec 07, 2010 | Jenn-Air Cooktops
Burner will not light
Try running the burner thru the dishwasher this does work sometimes, if not I would replace there not very expensive.
www.appliancehelponline.com
Mar 31, 2010 | Jenn-Air JGC8536 Gas Cooktop
Have a thermador pc366 six burner range, the 2
Did you get an answer on this? Have the same problem and the house call starts at about $100
Sep 21, 2009 | Thermador PC366BS Stainless Steel Gas...
Jenn-Air JED8345 one burner does not come on
The switch for the burner is bad and needs to be replaced.
Jun 25, 2017 | Jenn-Air JED8345 Electric Cooktop
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Viking Gas Burner issue?
is this a sealed burner unit? if so the burner base (the heavy brass part under the burner cap) has to be sitting just right. you will notice that it has holes around the the sides make sure that where your ignitor sparks to it that it aligns with the lowest hole on the burner base. if you have a great flame all around the burner after checking what i mentioned i would replace the spark module. if it continues to drive you crazy with the noise - just unplug it. the burners will continue working fine without power.
Dec 23, 2008 | Viking 42 in. Professional Series...
Kenyon B41516 Mediterranean Series 12" Smoothtop Electric Cooktop with T Logo
57 people viewed this question
Top Kenyon Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kenyon Cooktop Expert? Answer questions, earn points and help others
