Need to set up a sonystar 8898 for satellite tv
Pls I have a sonystar projector tv model PV43F90, suddenly develop a fault of no light on the screen but if I use the remote control to either change channels or volume there is an indication at the front...
I had a look around for Sonystar with no direct luck save for a eu website which looks eastern european, I would myself seek advice from Audio, Visual and Satellite forums who may help identify it under another make/model as many items of recent times came to be made in ex soviet bloc countries because of cheaper labour costs. Philips had theirs selling cheaper models through large UK outlets (better not say who) and I have seen similar rebadged Bush and others that herald from that area.
Sorry unable to help you further, good luck........
Feb 15, 2015 | Televison & Video
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
How to set 42" Insignia from 780p-1080p.(don't know if that's the problem)T.v. connected to satillite and still get snowy ,blurry picture..My old t.v. with satillite looked better than this new t.v
You may need to adjust the native resolution passthrough setting on your satellite tv box. Besides that you set 1080i on the satellite tv box not the tv. The tv just picks it up automatically. You may call the satellite tv company directly to ask for assistance in completing these two things.
May 07, 2010 | Insignia 42" LCD Flat-Panel HDTV
Connecting Toshiba Satellite A105-S2071 to TV with S-video/RCA
after hooking the pc to the tv make sure the tv is set to the correct input, hit alt+f5.
Aug 06, 2009 | Toshiba Satellite A205-S4617 Notebook
Replacement for toshiba satellite A105-S4244 dvd r/rw drive
Sure--the best one is e-bay!
Whenever I need something like this, I find it on e-bay. But if you really need to contact a company, try Spare Parts Wearhouse at 877-253-8898. National Parts Depot at 800-524-8338 may carry Toshiba parts.
I'd almost bet that the part you need is not made by Toshiba, though. Take it out and when looking for a replacement look for the mfg. name and the model.
Feb 09, 2009 | Toshiba Satellite A105-S171 Notebook
Necesito Saber el modelo de placa Toshiba L300-SP5807
Hola, Usted puede obtener las piezas de los siguientes sitio web. http://tinyurl.com/at8t9f Usted puede llamar a este número si se encuentra en los EE.UU.. 1-877-253-8898. Thanks Proton
Jan 29, 2009 | Toshiba (P000204210) Motherboard
Satellite input
Most tv setups require that you change the input source to gain the ability to watch the proper peripheral e.g. if satellite is connected on video one and the dvd is connected to the tv on another input such as video 2.
If the satellite runs into the dvd unit and from there the dvd is connected to tv you may have to power off or on the dvd player to resolve conflict.
Another problem may be the resolution setting if your tv is Hi Def. Set the tv and receiver to the resolution e.g. 1080i.
You can also changed the way the satellite is connected to the tv possibly if you have other inputs.
Check the channel also, if the unit is connected with coax it would more than likely need to be on ch 3 or 4 if you are at the satellite receiver box location. If you are at a stand alone tv off of a dual tuner you may need to search the channels for the right source both air(analog) and cable(digital).
Hope this helps you out. If I can be of more assistance let me know.
Sep 07, 2008 | Proscan PS60690 60" Rear Projection...
Ctgv-2736 satellite connection
no need to contact you can use any brand of tv set
Aug 02, 2008 | Broksonic CTGV-5463TCT TV
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
