Question about Toro LX466 22HP Lawn Tractor 13RT61RH244
Will not move while in gear - Toro LX466 22HP Lawn Tractor 13RT61RH244
Buick gear shifter moves freely and wont shift gears
you can shift it at transmission by hand to neutral or park and have someone inside start the car and you manually put in gear under hood and drive it to shop or garage, wherever
Feb 06, 2013 | 2000 Buick Century
It moves into gear but wont move
transmission has gone out also check tranny fluid
Mar 14, 2010 | 1986 Cadillac Seville
2001 Hyundai - reverse gear is inoperative. The
If I understand you correctly, you have ALL forward gears working, but reverse doesn't?... then the problem is in the transmission itself or the linkage on the trans linkage into reverse.
Oct 18, 2009 | Hyundai Accent Cars & Trucks
Transmission not shifting into gear
if stuck in park sound like the shift lock solenoid. try moving it with the key turned to the first click. or is it not moving after it is in gear?
Aug 07, 2009 | 2002 Kia Spectra
2007 chevy impala won't shift into gear, shifter moves, but doesn't go into gear
It is either the shifter cable or maybe the shifter linkage came undone..
Rate well ;o)
Jul 30, 2009 | 2007 Chevrolet Impala LS Sedan New Cars
My sons klx 110 grinds when downshifting
While sitting still the gears are not moving. This sounds like a slightly bent shift fork. In the diagram below the slider gear moves left and right to engage the gears. The gear "dogs" fit into holes cast into the stationary gears. The grinding takes place as the fork moves the slider into first gear but the dogs are not getting moved the full distance needed to fully engage the gear because of the bent fork. The center case must be split to gain access to the gears and shift forks.
A “very helpful” rating for this answer? Thanks!
Jun 30, 2009 | 2006 kawasaki KLX 110
During start Automatic gear does not change
sounds like a brake switch failure. located under the brake pedal and is fairly simple to change out.
Jan 30, 2009 | 2005 Honda Civic
Toro LX466 22HP Lawn Tractor 13RT61RH244 Logo
27 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
