Question about Epson Computers & Internet
Epson 1410 adjprog exe - Epson Computers & Internet
5 Suggested Answers
SOURCE: i cant run the adjprog.exe even if changed the date of my computer
1111111
Posted on Nov 08, 2008
cns assoc
  • 677 Answers
SOURCE: Parts inside your printer are at the end of their
Found this on the web site., link below. If anybody find this information
Helpful, pls rate me.
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
Parts inside your printer are at the end of their service life “Today I had the joy of fixing an Epson Stylus C46 UX printer.”It had the following error: “Parts inside your printer are at the end of their service life. See your printer documentation.”
After a little searching I discovered that most people were saying that “It is simply not worth repairing”, however, I took that as a challenge, and decided that if I was going to throw it away anyway I might as well try to fix it first.
Before long I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues. This is the process I used after reading details on that page:
  1. Unplug the power and USB cables from the printer.
  2. Prepare your work area by putting scrap paper down. Have some spare, just incase. You may also require tissue paper. It is also recommended you use protective gloves as the ink will stain your skin for quite some time.
  3. Unscrew the screw at the back of the printer.
  4. There are two or three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
  5. At the back of the unit you need to locate some white pads, or sponge type things, initially they will seem fine, but they will infact be full of ink. You need to grab a pair of pliers and pull them out one by one, there should be four, put them on your scrap paper.
  6. Take the scrap paper with the pads on to your sink, turn on the hot tap and hold each one under the tap using the pliers until the water runs clear. If you have protective gloves on it may be worth squeezing the water out also.
  7. It is recommended that once you have done this, you let them dry.
  8. Now return the pads back into the printer.
  9. Put the printer back together, (mind out for the paper alignment, and give it some force), not forgetting the screw at the back.
  10. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
  11. Download and install the SSC Service Utility for Epson Stylus Printers.
  12. Select your printer and model number (There is no Stylus C42 UX, so select Stylus C4x), then close the window.
  13. If it asks if you replaced with the pads; say “YES”. Then close the window.
  14. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
  15. A menu will appear, from here you can click on “Protection counter” (its a red cross), then “reset protection counter”.
  16. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
Done! Additional troubleshooting… If you have problems with paper feed, take it apart again, check everything is in place correctly, push things together tightly, and put it together again. If you have trouble with print quality, open the lid, clean any ink residue, use the SSC Service Utilitiy to clean the heads.
Thanks and Good Luck Please Rate Me
Posted on Apr 05, 2010
albertgamayo
  • 10 Answers
SOURCE: Adjprog.exe for epson L200
You can go to printerclinic.com and download a reseter of epson l200 or l100
Possible password: printerclinic.blogspot.com
Reseter of l100 and l200 are the same
Here's the instruction..
1.extract files
2.click the adjustment program
3.click the particular adjustment mode
4.check the three box on the left side then click initialization
5.then off the printer then on again
Posted on Apr 06, 2013
  • 5631 Answers
SOURCE: adjprog.exe
You can get Adjprog.exe from here
http://www.imprek.com.ar/reseteadores/tx125_t25_tx135.rar
Solucionado AdjProg exe para epson tx 135 alguien lo tiene Impresoras...
Posted on Sep 15, 2015
1.extract files
Apr 06, 2013 | Epson L200 Original Continuous Ink Tank...
Message tells me my Epson 250 needs service - ink pads full. Can I fix this myself as will cost more than the printer is worth if I take it to a service store?
Steps :
Before the prototypal run AdjProg take the steps below
- Machine On
- Contain the enter properties of restricted AdjProg
- Run the line Companion pyrotechnic introductory Stamp according to the modified Stamp AdjProg.
- Change the engagement to flowing day qualified AdjProg ( july, 11 2007 )
- Run the registration promulgation
- Superior Get
- Select a specific advance average
- Select "Ravage ink pad sideboard - OK
- Click the "initialization"
- Movement off the machine and on again
Mar 21, 2011 | Epson Office Equipment & Supplies
Want to know how to reset my epson R390 printer
Hi!
Download Printer Resetter here: http://www.mediafire.com/?3lbjlqmsqa9
1. Turn on the printer 2. Set the pc date setting to 1 January 2007 3. Adjprog.exe run from the extract of a folder (or locate the file or application. Exe and run it) 4. Click accept 5. Click on the particular mode adjustment 6. Go to interview Then select waste ink pad counter then click ok 7. Click "button box" until it is done then click "initialization" button and then click "finish button" 8. Turn off the printer for 5secs then turn again 9. Set the date today.
Cheers!
Feb 25, 2011 | Epson Stylus Photo R390 InkJet Printer
I have the two flashing red lights and I have switched etc., but still have the problem.
This is probably a Ink Absorber Error. Epson has a safety feature built into these machines that will disable all functions once a certain amount of prints have been reached. Search google for AdjProg.exe. this is a tool to reset the counter. I would sugest replacing the Ink Absorber Sponges aswell.
Good Luck
Dec 09, 2010 | Epson Stylus R265 InkJet Photo Printer
Parts inside your printer are near the end of their service life.
i have a problem with my printer epson stylus C90. may i know what to do when parts of my printer are near the end of their life service.? how can i fix it?
Dec 07, 2008 | Epson Stylus Photo R300 InkJet Printer
Waste ink pad
to Reset Waste Ink Counter
  • RUN AdjProg.exe file Epson C90
  • choose Particular adjustment mode
  • select waste Ink pad counter
  • Klikinitialization
That’ all!
Jun 01, 2008 | Epson AcuLaser C900 Printer
Computers & Internet Logo
670 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
