Question about Rival 8605-M 6 Quart Ice Cream Maker
Need cover for canister
Cover that goes on canister and stirrer comes up thru the center white in color
Where can we acquire a new cover?
Unfortunately Rival doesn't make replacement parts available for their appliances. You can contact them directly at Sites rival products Site However I haven't ever been able to get replacement parts through them.
I have found the 90% of canister style Ice Cream makers have the same size lids. In the past I have purchase West Bends Ice Cream maker lid and it fits perfectly on both my Rival ice cream maker as well as my Back to Basics model.
Here is a link to the parts on West Bends site:
IC10885 Ice Cream Maker
The lids is part number U66-2, and is only a couple of dollars from West Bend.
-Colleen @ Mending Shed
Apr 14, 2015 | Rival Ice Cream Makers
We need the cover for the mixer.
Unfortunately Rival doesn't make replacement parts available for their appliances. You can contact them directly atSites rival products Site However I haven't ever been able to get replacement parts through them.
Here is a link to the parts on West Bends site: IC10885 Ice Cream Maker
Apr 14, 2015 | Rival 8804-BL 4-Quart Oval Ice Cream...
Where do we acquire a new cover?
Apr 14, 2015 | Ice Cream Makers
Tub center rusted out
Dawn, Try http://www.cottagecraftworks.com/ice-cream-frz-parts-white-mountain-freezer-tub-center-p-1613.html. There is a plastic center listed on their page.
Jan 30, 2014 | White Mountain F69206X 6 Quart Ice Cream...
Ice cream maker instructions
I have the booklet for this machine.
1) you can use any IC recipe as long as it does not exceed 1 quart. This is for vanilla:
1/2 c sugar
1 1/4 c half&half
1 1/2 c heavy whipping cream
2 eggs 2 tsp vanilla
with mixer beat eggs and sugar until thincl and cream colored. Addthe cream and vanilla mix well.
the machine:
you want to put the freezer cylinder in a plastic bag (to prevent freezer burn) and then put it in the back of your freezer until completely frozen 6 to 22 hours. You should not be able to hear liquid slosh when you shake it. For making stuff quick they recommend keeping it in the freezer in the bag.
step one: Put maker on flat surface.
two: Put the mixer bowl on the base.
three: Place frozen cylinder into to the mixer bowl (the big one) do this when you are ready to start the IC because the cylinder begins defrosting right away.
four: set the paddle on top of the cylinder, placing the peg on the freezer cylinder inside the peg hole on the paddle
five: Place the cover over the mixer bowl, locking the grooves on the motor base. Plug in, turn on, the bowl and cylinder will begin to turn.
six: Pour the recipe into the feeder hole of the cover then put the lid on.
You will need 20 to 40 minutes or until mixture is frozen. Don't stop the machine until done. If you want hard ice cream spoon the soft serve into an airtight bowl and put it in the freezer till it is like you want it.
Hope this helps, Elizabeth
May 17, 2009 | Ultrex Double Canister 2 Quart Ice Cream...
Need replacement can for Sterling Catalog No. 165A (Is Rival 8550x Equivalent?)
Richmond Cedarworks has folded. Rival/White Mountain do not have parts for the replacement of your canisters. Richmond has went under for bankrupcy or were bought out by some private sector. The parts offered by Rival/White Mountain are different sized for all of the Richmond products. As there are no parts available, anyone looking for parts should be directed to either commercial supply stores or stores that repair/rebuild old kitchen equipment.
Sep 09, 2008 | Rival 8550-X 5 Quart Ice Cream Maker
Motor does not stop
If you check the instructions that come with the white mountain ice cream maker, they talk about the problem of the custard not freezing in the center. It is because you have your salt to ice ratio out of whack. Too much salt causes a situation similar to your description. You want to shoot for 12 degrees and if you add too much salt, it goes lower than that.
There are copies of the original instructions online (usually in a pdf file format) that are worth looking for and reading. Rule of thumb 1 to 5 ratio of salt to ice.
May 26, 2008 | White Mountain F69206X 6 Quart Ice Cream...
Gel Canister replacement
These are now discontinued, but I did come across a couple of sites under GE Ice Cream Makers Model 106765 where you may have some luck.
Dec 19, 2007 | Gel Canister 106765 1.5 Quart Ice Cream...
Rival 8605-M 6 Quart Ice Cream Maker Logo
54 people viewed this question
Top Rival Ice Cream Makers Experts
Henry  Thomas
Henry Thomas
Dan Webster
Dan Webster
Stan Skaggs
Stan Skaggs
Are you a Rival Ice Cream Maker Expert? Answer questions, earn points and help others
