Question about Razor Dirt Quad Bike
Wont move i unpluged a battery on a good bike and placed it on a bike that wont work the bike that doesnt work still wont work with this battery that works in another bike.I checked the fuse its good
I placed a new battery to my activa bike on 13/05/16. After two days while the bike is in running, horn , indicator lights went off slowly. Then bike also went off from moving.
did you leave lights or key turned to on position or the battery didn't have a good charge when you parked it. Did you kick start the engine? Bike may need a tune-up.
May 16, 2016 | Motorcycles
The rev meter on my motorhispania rx125r doesnt work, now the other day after i cleaned it 'NO CDI' was flashing on the screen. Everything else works fine, just the revs, they move slightly to the...
I have the same issues,only the rev counter works but the di gi speed is all over the place,then had "no cdi" indicator on display,,bike wont start now just coughs n splutters,ten cuts out,i think the is a cdi issue,dealer collecting bike tomorrow i will update after diagnosis.
May 10, 2011 | Motorhispania Ligero RS 150 Motorcycles
Bike engine light came on shut bike down wont start battery level is 10.6. Everytime I try to start the bike I get a code 0005 raw or so I think that's a code anyway. Any ideas what's wrong oh I checked...
Battery needs to be over 12v for the bike to start, with the bike running it will be about 14v
if you charge the battery and it wont hold 12v----new battery
If the bike starts and doesnt show 14v aprox---- new regulator
Apr 11, 2011 | Ducati Monster 696 Motorcycles
My ducati m600 wont start. i thought it was the battery i charged it and still wont start. there is no sound at all from starter button. help me out pls
If the battery is up, and the key is the right one, nobody messed with the disabler system, kick stand up? Bike in gear? Check the ignition relay, make sure bolts are tight, not corroded, check battery terminals, check water in battery, if it has water, check the wire to the starter, not corroded, broken, and the last place to look, if it hasn't started yet, is behind the headlight , there is a plastic case full of wires, it gets wet and corrodes, check it out, it would be the last place to look.
Oct 23, 2010 | 2001 Ducati Monster 600 - Dark - City -...
My pit bike 125cc wont fire up
Try unpluging the cutouts.they are usally on 2-3 places on these bikes ,brakes,also check the fuse that is on the red wire comming off the battery it will be blown or end of fuse holder will be pushed in and not touching the fuse.
Apr 13, 2010 | RTO Pit Bikes
When i pull my clutch lever in, it doesnt engage the clutch
First thing is to make sure you don't have motor oil in the engine. Wet clutches and motor oil are not compatible. Use only the oil sold at motor cycle shops. Do that before tearing into the engine or making any radical adjustments. Good Luck -Ned-
Sep 21, 2009 | 2003 Yamaha YZ 250
1995 hanoda 125 three wheeler will not change gears stuck and can not get it out of gear - is there an adjustment or a online manual that i can read to fix the problem - thanks
make sure the clutch cable is properly adjusted, next thing would be to check if your clutch itself is in good condition and adjusted. to test, pull clutch lever in (with bike off) place it in gear, bike should move freely when pushed forward.. if that is all well and doesnt work good, you need transmision repairs,shifting forks probably bent.
Jul 10, 2009 | 1985 Honda XL 125 R
Mouse Is Recongnized but wont Move
On the bottom of the mouse is a little tiny button that say: connect or reconnect. Place the mouse close to the transmitter dongle (the do hicky comes out of a USB) and look for that button on the transmitter and the mouse to reconnect the signal.
(batteries are good ?)
May 14, 2009 | Logitech 9313960403 Mouse
Razor Dirt Quad Bike Logo
429 people viewed this question
Top Razor Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
RatanbssBD
Level 1 Expert
Betty L Kidd
Betty L Kidd
Are you a Razor Rock and Ice Climbing Expert? Answer questions, earn points and help others
