Question about iPhone Apps
My dad is rude and dgrumy to me for nothing
He was a about to woop my *****
Sending someone a bill for not showing up to a wedding?
Let it pass they said they could not come A sick child there nothing they could do .
Jan 04, 2017 | Weddings
04 Santa Fe burning smell running ac....
Sounds like the A/C compressor clutch has overheated and become inoperable. Open the hood, start engine, observe the compressor face. It should be turning and also see if that's where the noise and burning smell is coming from.
Good luck!!!
May 16, 2013 | 2004 Hyundai Santa Fe
Woop woop sound coming from left tire
It could be something stuck in the tire tread but that whoop sound is usually caused by a bad wheel bearing.
Jan 08, 2013 | 2002 Ford Expedition
2000 monte carlo / noise from rear wheels
That's what it sounds like to me also. I would put the rear up on jack stands and spin the wheels to male shure wich side it is. Don't forget to block the front wheels for safety as you will not be able to set your e- brake for this test.
Aug 27, 2009 | 2000 Chevrolet Monte Carlo
My dad blocked facebook using k9 nine web protection. unblock?
Hello, walterorlando
If your Father had used a parental control to keep you from visiting sites he'd rather you not, it says alot about the protection offered by K9 doesn't it? My advise is to listen to your Father once in your life and avoid any trouble of a wooping for breaking through that protection. Stop it, now.
Aug 13, 2009 | Dell Inspiron 1100 Notebook
The bread pan will not stay locked down. My husband toke it out and set it in again and it will start up again and 2-3 rounds of pladel and it pops out again. When will we go back to selling American made...
After contacting Breadman and following their instructions of repositioning the spring clips on the sides of the pan cavity, to no avail, I came up with a solution at least for me. With a strong pair of needle nose pliers I bent the tabs upwards on the pan itself to a full 90 degree position relative to the pan. I have made 10-12 loaves since with no problems.
Jul 16, 2008 | Breadman TR2500BC Bread Maker
Engine code
I own a shop, and think this; The light came on, and later (after ignoring it) it started flashing. If its flashing; it means you have a problem that requires attention right away, and should not be driven. You could have a problem that will do severe damage to the engine, and/or other components in the vehicle. If its not knocking, squeaking, or dieing in the road, then this must mean you can still drive it. If your dad is a mechanic, then I would suspect he's going to raise cane at you for ignoring the light. Should you not know something is wrong, and by ignoring the light you could be doing more damage to your car? Check it out before you even attempt to drive it anymore. If it melts down in the road, your dad is going to know. You sound just like my son. He won't check anything until it just dies completely, and then he complains about having to spend more to fix it, than he would have if he had just fixed it to begin with. I'll bet you would fix your computer if it was acting up, so why not your transportation? I don't mean to sound rude, and I'm in no way trying to insult you. I just think you are not doing your poor car any favors, and your dad may go off on you.
Glad to add my 2 cents worth!!!
Jun 26, 2008 | 1994 Chevrolet Corsica
AFTRON PORTABLE DVD PLAYER WON'T PLAY DVD OR ANY CD. MY DAD BOUGHT IT FROM QUATAR AND SHIPPED IT TO THE PHILIPPINES. AFTER A WHILE OF PLAYING SEVERAL DVD'S AND VCD'S, IT WON'T WORK ANYMORE SAYING THAT IT...
AFTRON PLAYER PROBABLY USED CHEAP LASER AND NOW HAS GOTTEN WEAK AND GONE BAD. I THINK THAT IS THE PROBLEM.
WHY ARE YOU USING ALL CAPS-LOCK??? THAT IS VERY RUDE
THANKS FOR READING
May 01, 2008 | Televison & Video
iPhone Apps Logo
73 people viewed this question
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
