Question about Toshiba e-Studio 232 Black and White Copier
Computer not communicating with toshiba e-studio 232 copier
Copier added to network, shows printer ready but documents are not printing
5 Suggested Answers
  • 10 Answers
SOURCE: Network printing issues - Toshiba e-studio 16s
try this:
start, printers and faxes
right click on the print driver , go down to properties click
click on ports
click configure port
click lpr in protocol
Lpr queue name PRINT
LPR byte counting enable
SNMP enabled
Try this and make sure your ip address is correct
Posted on Feb 06, 2008
  • 653 Answers
SOURCE: Toshiba e-Studio 350 - How to Print?
Did u install printer kit? It looks like a mini thumb drive, hooked to usb port?
Posted on Mar 08, 2010
KingDWS
  • 1606 Answers
SOURCE: I work for a school
This sounds like either a network problem or you don't have the correct driver installed. There are three types of drivers and the driver is different for the type of controller that is installed in the printer.I suspect that actually the problem here. You can download the different drivers from Toshiba. I would suspect that your network admin may have them for download somewhere. If not just download them from Toshiba and install again. If you have access to another computer that will print you can check what driver it is using. That might help to avoid a headache ;-]
Wish I could give you better info here but without being able to see the hardware etc I can only give you some general ideas.
Posted on Aug 29, 2010
  • 5 Answers
SOURCE: e-studio-232 adding toner problem
change the developer with the new one and change the sensor toner.
Posted on Jun 07, 2012
How do I unblock the feed to the printer?
What we have here is failure to communicate. If you go to your computer and pull up printer description and status, you may be able to cancel the pending print jobs but it may be necessary to shut down either or both devices and even disconnect the communication line.
The "out of paper" problem may be due to a fault at the printer such as being unable to detect that the paper tray is full.
Sep 10, 2015 | Toshiba E-studio 3530c Color Copier....
E-studio-232 adding toner problem
May 24, 2012 | Toshiba e-Studio 232 Black and White...
Does toshiba estudio 203 have a memory for past documents
http://www.ebookbay.com/ebook/935/toshiba-e-studio-200l-202l-230-232-280-282-smhh here is the service manual for Toshiba e studio 232/282
Jan 02, 2012 | Toshiba e-Studio 232 Black and White...
Mar 07, 2010 | Toshiba e-Studio 350 Copier
E-studio 232 print goes from computer but does not print out of printer
The Printer function is available when the printer kit is install. Like GM-1040 print enabler, GM-2070 printer/scanner enabler.
Feb 05, 2010 | Toshiba e-Studio 232 Black and White...
Printing PDF files
How do you do. **** reinstall driver.Most often this occurs because of invalid driver. The Pain that, **** to install the local driver not through network, but on cord of the port USB, if it need, will be a seal from network, ???????? the printer opened for all and all will be able to print through the computer, beside which USB on printer. Good luck you!
Sep 15, 2009 | Toshiba e-Studio 232 Black and White...
Setup photocopier wirelessly
To change paper size setting, press the user function-->user-->drawer. In order to do network printing using network port (RJ45), u need to make sure printing kit (GM107x) is installed on your machine. It looks like an thumb driver. But u can also enable the 60 days trial periods in order to try out the network printing.
Jun 03, 2009 | Toshiba e-Studio 232 Black and White...
Toshiba e-studio 207 "local device communication error
On the host pc that connected to the MFP, check the paper size setting under the driver properties.
Apr 22, 2009 | Toshiba e-Studio 232 Black and White...
E-studo 232
In order to print, printer kit need to be added ( a USB dongle ).
Then, static IP address need to be configure under the network setting of the MFP. Next, u need to install driver to your client PC. ( There is a cd along with the manual )
Dec 14, 2008 | Toshiba e-Studio 232 Black and White...
Toshiba e-Studio 232 Black and White Copier Logo
14 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
