Question about Philips Magnavox MWR10D6 DVD Recorder
My Wr 10D6 won't format disc after 40%
Did show it was recording bit it would not finalize ( Show error
4 Suggested Answers
  • 6 Answers
SOURCE: WHEN I RECORD A DVD.
Sometimes DVD players cannot read a DVD+R disc, only DVD-R can be played. (or vice versa) For example my old XBOX cannot play DVD+R, but it will read a DVD-R just fine.
So if you have finalized your disc and it still won't play on a certian player, try the other type of disc. (DVD+R or DVD-R)
Posted on Jan 05, 2008
  • 4 Answers
SOURCE: how to finalizing after i recorded
from page 36 of the manual....on the remote control1.gif press SETUP use the arrow key to select "DISC EDIT" press OK Use the arrow key to select FINALIZE press OK. A confirmation window appears, use the arrow to select YES and press OK. If you still cannot view on a different DVD player, you may want to check to make sure that your disc's are compatible with the new player.
Posted on Jan 28, 2008
guitarman002
  • 80 Answers
SOURCE: How can I record a tv show onto a blank disc? I
Make sure you have the right DVD disc and the disc is clean if you do... (2) make sure you connected it right and are fully seated. LINE IN on your DVD-R is for the recorder part LINE OUT on the tv is to send it to the DVD-R If you done that try another RCA cable or two That should fix it
Posted on Jul 15, 2009
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
Hi.I have CD Recorder Marantz DR6000.After reading and initalizing blank CD-R Audio next on display show OPC ERROR.It,s reading all audio CD,s,oryginal,and CD-R.When I wanna finalized old CD-R,recorded by...
DR-6000 only accepts CD-R audio or CD-R music discs, not the standard CD-R discs. the difference is that the audio and music discs have the OPC formatted differently and they cost a bit more because they include the royalties fee. Standard CD-R discs won't work in this recorder. The correct discs have compact disc "digital audio" logo on them.
Oct 01, 2010 | Marantz DR-6000 CD Player
CAN RECORD FROM VCR TO DVD+R, CAN PLAY DVD ON SAME, BUT CANNOT PLAY ON OTHER DISC PLAYERS. I THINK THAT THIS IS BECAUSE I AM NOT FINALIZING CORRECTLY. WHEN AND HOW DO I FINALIZE A NEWLY RECORDED DISC?...
Usually you finalize the disc after loading it with all the desired content (leaving a bit of space for the finalization). So if you are recording a TV show, depending on the setting (SP, LP, XP), you might finalize the disc after recording 4 1/2 shows. The How may vary by model but on my DVD recorder, I find the finalize command in the same menu area as adding a title and initializing a DVD-RW disc. So I press Setup to enter the OSD menu, then go down to Disc (looks like an optical disc) then right arrow to enter the sub menu. Then press down to Disc Finalize and the right arrow again and press enter. Select OK and Enter again. (RW discs can be unfinalized to add more content.) Then wait until the process is done.
I hope this helps.
Jul 09, 2010 | Philips Magnavox DVD/VCR Dual Player
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Magnavox DVD recorder...finalizing problem
The manual isn't too helpful either - "Recording error other than below," it says. There are a couple of possibilities. The Philips/Magnavox/Funai recorders automatically record in VR mode when you use +R discs (there are two possible recording modes - V Mode and VR Mode). Is it possible that you have switched disc types lately? If you are currently using -R discs, switch to +R and vice versa. The manual states that +/-RW discs take a while to initialize.
I couldn't find a full factory reset on that one, so you may have to unplug the unit for about 20 minutes to restore all the defaults.
Another possibility: Finalization requires some extra space on the disc. If you accidentally pressed the button that changes the recording format between SP, EP, LP, etc., you may not be able to fit the same amount of video on the disc that you were able to fit before. You can change the format by pressing the Disc Mode button on the remote - LP Mode will fit 3 hours worth of recordings onto a 2-hr disc and is considered a "medium quality" recording. Try changing the Disc Mode to LP and see if it will finalize the next disc that you record. The downside of this possibility is that the discs that you have already made that are giving you errors are not "fixable" - you will will have to re-record the shows to a new disc in LP mode.
-Tha Mp3 Doctor
Feb 11, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Finalizing
that's because u r in HDD mode. Change drive select to "dvd" , then "functions" will show: "disc setting" to include, disc name, pick menu, select first play, and Finalize.
Jul 17, 2008 | Panasonic DMR-E85H DVD Recorder
WHEN I RECORD A DVD IN MY MWR 10D6 DVD RECORDER IT IS NOT ABLE TO BE PLAYED IN MY OTHER DVD PLAYER WHICH IS A TOSHIBA. WHEN YOU PUT THE DVD IN IT ALWAYS SAYS PLEASE CHECK DISK. THIS ONLY HAPPENS WITH DVD'S...
When you burn your DVD the disc has to go thru a FINALIISATION process before it can be used on other DVD players. Sounds like either your recorder hasn't run the finalisation or it doesnt do one, in which case your DVD's wont work on another player. Check thru your menu's for a FINALISATION option and make sure you run it.
Marty.
Dec 29, 2007 | Philips Magnavox MWR10D6 DVD Recorder
8mm dvd
Have you finalized the disk? I would suggest that you put it back in the camera and finalize.
Dec 27, 2007 | Sony Handycam DCR-DVD201 DVD Camcorder
Cyberhome 1200
I have a cyberhome 1600 dvd recorder and I need a code to program it to my bell remote but can not find any codes for the cybehome. can someone help with the codes
Nov 23, 2007 | Cyberhome DVR 1600 DVD Recorder
Finalizing and reading discs
What a load of rubbish this camcorder is and Samsung customer service is a load of rubbish too.
Jul 11, 2007 | Samsung VP-DC161 DVD Camcorder
Philips Magnavox MWR10D6 DVD Recorder Logo
37 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
