Question about Harmon Kardon Harman Kardon Avr 25 Ii Stereo Reciever
Harmon Kardon avr 25II turns off by its self when powered up
On power up it goes on and then turns off after a second or two
When i turn on my harmon kardon avr 165 it shows ''Protect'' and then it turns off again?? what can i do :)
I would try disconnecting the speakers, then turn it on. If protect still shows with no speakers connected, then it needs to go to the repair shop- Might be a blown power transistor.
Oct 24, 2013 | Harmon Kardon Harman / Kardon AVR 165...
Harmon avr 445. Wont. Turn on
First check power cables and fuse
Jul 08, 2013 | Audio Players & Recorders
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
My Harmon Kardon AVR 2600 goes to protect mode when powered up. After many tries it will fire up but at times it's up to twenty times. I did load the software upgrade 6 months and it has been fine
Check all speaker wiring for shorts, if okay! there is a problem in the audio output stage of the unit or the protection circuit is not working properly. I would suggest a pro to evaluate.
Apr 02, 2012 | Harman Kardon AVR 2600
Hi, I have a Harmon Kardon Model No. AVR 325 that keeps clipping. When I push the power button the display turns off like a second after I push power. Seems like its a easy fix. Nothing if fried visually...
it sounds like Amp burned, but not all burn parts you can see, you have to measure them by DMM. I guess at least one AMP transistor shorted. you can check SPK terminals by DMM DC, it can be easy to find different with other one
Mar 19, 2011 | Harman Kardon AVR 325 Receiver
My receiver doesn't have a dedicated subwoofer output, can I still hook up a subwoofer? I have a harmon kardon avr 25
That would depend mostly on your subwoofer. There are some that slave off the front left and right speaker outputs and still pass the amp's power to the Front Speakers. That would be the only way that would ensure volume control.
Otherwise you have to feed a self-powered sub from the Tape Outs but that won't allow volume control from the H-K.
May 29, 2010 | Harman Kardon AVR 25 MKII
Harmon Kardon AVR 5
Assuming that the system is properly installed and was working ok before, the problem is usually a blown output amplifier in one channel and the receiver disconnects the speakers to avoid damaging them. In this case, professional repair is required.
Nov 15, 2009 | Harman Kardon AVR 5 Receiver
My Harman/Kardon AVR 140 is stuck on stand by mode
I have the same problem on my AVR 1550 - its been bugging me for ages then it works again, then it doesn't ...
Aug 28, 2009 | Harman Kardon AVR 140 Receiver
Harmon Kardon AVR-55 fuse schematics
F101 is 8 amp / 250 volt slow blow
F103 is 315 mA / 250 volt slow blow
Jan 11, 2009 | Harman Kardon AVR 55 Receiver
Harmon Kardon Harman Kardon Avr 25 Ii Stereo Reciever Logo
13 people viewed this question
Top Harmon Kardon Audio Players & Recorders Experts
Lawrence Oravetz
 Grubhead
Grubhead
Ngoro
Ngoro
Are you a Harmon Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
