Question about Garmin StreetPilot C330 GPS Receiver
Map update notice screen
Pressing the "OK" button does nothing. Powering off/on does nothing. Pressing reset button does nothing!
The unit is stuck on the map update notice screen.
Drivers are current
software is on latest version
HELP
Resetting or trying to recalibrate the touchscreen does not work for this problem. Every time I try to reset or recalibrate, the Map Update Notice immediately pops up and I have not found a way to bypass this screen. I think this may be a glitch programmed by Garmin to force users to buy an upgrade after a couple of years.
Posted on Jun 20, 2009
    Brigadier General:
  • 4,090 Answers
HOLD THE ON OFF SWITCH DOWN AND youPRESS RESET This should reset it back for t
  • rogerdstultz Mar 15, 2011
    On and off nor reset worked same proplem. up date screen will not go away
Garmin nuvi 2639lmt logo flashing
Try a soft reset:
To reset the Garmin device, turn off the device by pressing the power button on the top of the device. When the unit is off, press your finger to the bottom right corner of the screen and continue holding while pressing the power button. A prompt will appear on the screen confirming data reset. Click Yes.
If that doesn't work, try a factory reset:
https://www.youtube.com/watch?v=D_-zumajbaA
Nov 17, 2016 | Garmin nuvi GPS
Error. No Mapping Found Press esc in 5 sec to skip startup.nhs Shell>
Hard reset your tablet.By Pressing Volume and power button.Then your tablet will be ok.
Apr 30, 2016 | Tablets & eReaders
My Garmin nuvi 1390T will unlock the screen without entering all or part an incorrect password. It usually takes a while to pick up the satelite signal. The touchscreen needs to be more responsive to the...
Try performing a soft reset or a hard reset to the unit.
The soft reset is done by holding down the power button for at least 10 seconds and allowing the unit to power back on.
A hard reset is done by pressing and holding the bottom right hand corner of the screen while the power is off and then pressing the power button on. A pop up will appear asking to confirm the reset.
The hard reset will erase the user data, so it is advisable to save the data if possible.
Installing and running the Garmin WebUpdater to load or reload the latest update will resolve most issues.
download the latest version of WebUpdater software
The touch screen may need recalibration.
This can be done by pressing and holding the top left corner of the screen will powering on the unit.
Keep pressing the top left corner of the screen until the calibration screen appears.
Use a stylus or the round back part of a pen to press the dots to calibrate.
Once the calibration is done the unit will continue to boot up showing the Garmin screen.
You may also want to contact Garmin support for assistance.
http://www.garmin.com/us/support/contact
Sep 27, 2011 | Garmin nuvi 1390T Car GPS Receiver
When I turn my Garmin 550 on it says loading maps, then goes to the select a local: It's frozen their on United States i push OK and nothing happens can not change the Locale it's frozen I tried...
Hi tkfranks331,
Press the power key and hold it if the screen of your Zumo is frozen. Keep holding the power key while pressing the key that has a plus symbol ("+") on it. This will reset your device and unfreeze the screen. You can also try calibrating the screen by pressing the power key for one full minute.
If this does not work, please follow these steps.
1. Update the internal disk software. Download and install WebUpdater on the computer. Please visit this link to download the WebUpdater.
2. Open WebUpdater on the computer.
3. Connect the Zumo 550 to the computer with its USB cable.
4. WebUpdater will automatically search for updates.
5. Follow the prompts to download any pertinent updates for the Zumo 550.
Hope it helps.
Thank you for using FixYa.
Aug 17, 2011 | Garmin zumo 550 GPS Receiver
Garmin Nuvi 205 - when I switch it on the maps load up and after the warning screen a screen appears with the message "Stay up to date with your Garmon Safety Camera Data at my.garmin.com" I try...
You probably need to update the unit at their website. In the meantime, you can try the reset button There is one, but it's kind of stealth - it's on the angled edge of the bottom of the device, in a square "hole". Pressing the corner of the screen resets user data only, not the actual device. Good luck!
Apr 29, 2011 | Garmin nuvi 205 GPS Receiver
Map Update Notice. Locked up. Can't press OK. Stuck.
there is a reset button, you need to reset the unit.
Sep 28, 2009 | Garmin Nuvi 350 Car GPS Receiver
Map Update Notice
a tricky pice of software design by Garmin to make you go and upldate ton avoid the nag screen
Jun 28, 2009 | GPS
When booted up, I get a Map Update Notice.
I solved this problem by pressing my finger where the OK button is before I turn the nuvi on. That worked for me,
Mar 21, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
No power to my ICN 520
Have you tried the reset hole? make sure there is nothing stuck in there that could be pressing on the button. When you press and hold the reset button the screen stays blank.
If you press the reset button does the unit turn on? Mine turns on when I press the reset button even after I turn the battery off then back on.
Hope this suggestion might help you restore functionality.
Jun 08, 2008 | Navman iCN 520 GPS Receiver
Frozen screen
Resetting Your c330
If your unit locks up, press the Power button to turn off the unit, then press again to turn the unit back on. If this does not help, reset your C330.
1. Place your thumb nail in the groove located under the Garmin logo on the face plate.
2. Gently pull off the face plate.
3. Press the Reset button.
4. Turn the unit back on; it will operate normally
Apr 04, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
515 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
