Question about Marin B-17
Marin Bicycle Serial F520JSB027 - Marin B-17
How to change bearings on a bicycle
Without you being more specific about which bearing and what bike you have the best I can give you is these two sites:
Repair Help and Education
Sheldon Brown Bicycle Technical Information
The process you are referring to is called overhauling bearings, and the procedure and tools can differ greatly depending on which bearing - hub, headset (fork), or bottom bracket (crank) as well as the specific type of each one. I strongly advise you to study the instructions on the above sites first, then refer to videos to see the process. Many videos are incomplete or even include incorrect info.
May 14, 2016 | Marin Mountain Bikes Cycling
Who made this bicycle frame?
most likely a trek. Google Trek serial numbers for more info.
Jan 01, 2016 | Cycling
Bicycle serial number Want to know make and model of my bicycle the serisl number is ESW7R0725 60312
Sorry, comprehensive databases for bicycle serial numbers do not exist.
Sep 20, 2014 | Cycling
try this search: https://duckduckgo.com/?q=bicycle+dating+codes
If it's a potential Raliegh I recommend this: http://sheldonbrown.com/retroraleighs/dating.html
Mar 23, 2014 | Cycling
I have a marin quake 7.3 xlt and am running the 150mm maxle dropouts. when stationary if i push sideways on the rear wheel there is a clicking noise , this noise also happens when i turn corners hard and...
A few possible guesses.
1) the hub is loose and needs to be adjusted
2) the Freehub is loose and needs to be adjusted
3) the wheel is not securely in the frame
4) all these things
5) something inside the hub or hub assembly is broken
Solution: for all these take the bike into your local shop and have them take a look.
There is one other possibility, your spokes are not at full tension and the spokes are clicking against each other when you put enough lateral force on them. Again you want the shop to retension the wheel.
Depending on the wheels you have you will either need special tools to fix, parts, or special knowledge or all these. So better to pass on to a shop that has some experience working with this type of bicycle and get it done right once.
Mar 20, 2011 | Marin Quake 7.8
Bicycle brand name
Does it have to be an original part? Most any parts on a bicycle are interchangable with other bikes.....good luck with it.
Mar 23, 2010 | Cycling
What chain set type do I need for my Marin Hybrid Bicycle?
SRAM and Shimano both make good quality chains. Try to use the same chain type as what was on your bike originally.Here are two good sites with helpful articles:http://www.parktool.com/repair/byregion.asp?catid=5 and http://sheldonbrown.com/chains.html
Oct 23, 2009 | Cycling
Marin B-17 Logo
Top Marin Cycling Experts
John Egan
John Egan
Are you a Marin Cycling Expert? Answer questions, earn points and help others
