Question about Malibu Hardware & Accessories
Connections for Malibu timer
158LV9936
We have an older Malibu 300w low voltage transformer that has a non-working timer and want to install a photo eye on it. The instructions for the photo eye as well as recent IFU from Malibu show 3...
How about this solution:
Don't use the photo eye from Intermatic, since unsure if older timers might not be made for that feature.
Instead, plug power pack into photo-eye timer.
Or plug power pack into ordinary wall timer:
Copy following links for resources:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#TN
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Call Intermatic and they might have solution for photo eye.
Gene
hh
Oct 06, 2013 | Intermatic Malibu 300W Power Pack...
Malibu transformer with plastic fittings how to connect
1) Copy following link for full resources on operation, wire length, bulb wattage, warranty, troubleshoot, etc
2) Add comment Dec 2012 for more qassistance
Dec 15, 2012 | Malibu ML600TW - Low Voltage Power Pack -...
I have lost some of the little tripper clips. How do I get more replacement clips. Thanks for your help! Ron Leach
You posted under malibu/Intermatic power pack.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
If you have a different Intermatic timer, open following link:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
If you do not have Intermatic timer, then add a comment with more information about the timer, including full description and what timer is connected to, and if this is plug-in or hard-wire timer.
Also check following link for other timers:
Jul 14, 2010 | Malibu ML88TL 88Watt Low Voltage Power...
I have a malibu MLw200RT Low Voltage Transforer ... on the back it has an A B & a C terminal ....... there are 2 wires ...... should one of the wires be connected to A and C is intended to be use for...
Connect wires to terminals A and B.
Terminal C is for photo-electric eye only.
For more information on Intermatic/Malibu power packs showing photo-eye, troubleshoot steps, replacement trippers, useful links, warranties and tips:
Jul 11, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Intermatic Inc. ML121RT Low Voltage 121-Watt Power Pack with Timer: I've had malibu lights for around 4 years,I have ...
If other lights are working the power pack is OK. Usually, as in your case, if changing the bulb doesn't work, check the connection where the light ties into the main run.
May 17, 2010 | Malibu Intermatic Inc. ML121RT Low...
Malibu 600 watt transformer timer not working. Can turn on and off w/ the switch but the timer isn't functioning.
The timer motor is probably bad. Unfortunately, Malibu transformers have very few user servicable parts :-( , and the timer motor isn't one of them. One cannot even access the internal connections. If you recently purchased the transformer, return it to the store. If the transformer is less than 5 years old, it's still under warranty. In that case visit the Malibu website for instuctions.
Oct 31, 2009 | Malibu Intermatic Inc. ML121RT Low...
Malibu ml200rt internal wiring schematics
If you have a meter you can test for 12 volts AC on the output of the transformer. They go to terminals
A & B
Jun 22, 2009 | Malibu ML200RT - Low Voltage Power Pack...
Hardware & Accessories Logo
Top Malibu Hardware & Accessories Experts
Gene Haynes
jdthefixer
 Kenneth
Kenneth
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
