Question about Mopar Performance Dodge van/wagon - full size belt, lap buckle half. 1992-93-94, 1994
Where is location air pump relay on 00 oldsmobile silhoute
Where is the fuel pump and relay located 2.5 4 cylinder cutlets sierra 1985 not getting fuel when I pour gas in throttle it starts
1985 Oldsmobile Cutlass Ciera 2.5L TBI OHV 4cyl
The Fuel Pump Relay is located: Under hood, passenger side, rear engine area, mounted on upper firewall.Here's a link to what it look's like. http://www.autozone.com/fuel-delivery/relay-fuel-pump/duralast-relay-fuel-pump/oldsmobile/cutlass-ciera/1985/4-cylinders-r-2-5l-tbi-ohv/841098_0_0_7784 Here's another link to replacing your fuel pump, SAVE 20 ON ONLINE SHIP TO HOME ORDERS OF 100 OR MORE
Jul 16, 2015 | Cars & Trucks
Where is the water pump located on a 2001 olds. Intrigue?
If the engine is sideways, it would be located on the left side of the engine by the belts. See if a hose is hooked up to it.
Apr 02, 2015 | 2001 Oldsmobile Intrigue
Where is the relay switch for the fuel pump in a 1995 Oldsmobile cutlass ciera?
The fuel pump relay is located under hood, passenger side, front side of wheelwell, mounted in relay panel. Here is wiring diagram of fuel pump circuit:
Aug 24, 2014 | 1995 Oldsmobile Cutlass Ciera
Fuel pump relay location
Fuel pump relay is under the rear seat on the passenger side.
Feb 11, 2014 | 1997 Oldsmobile Aurora
The fuel pump relay on the 1991 Oldsmobile Toronado Trofeo is behind the glovebox, toward the top and to the right. There is a small relay panel that is not very easy to get to.
Jul 16, 2013 | 1991 Oldsmobile Toronado
How to install air pump 2000 bravada
I recommend that you will post your question under the correct category (Cars & Trucks) and maybe add more details to it, so it will be easier for Experts to understand the question and answer it.
Jul 25, 2012 | Dorman 1998-2000 Oldsmobile Bravada Air...
Where is the fuel pump relay located
1994 Oldsmobile Cutlass Supreme 3.1L SFI OHV 6cyl the Relay - Fuel Pump is located under hood, passenger side, front engine area, rear of headlight housing, mounted in relay block on upper fenderwell.
Remember rated this. Good luck.
Aug 10, 2010 | 1994 Oldsmobile Cutlass Supreme
My Olds Silhoute is overheating...
I must say it is a curious problem, we recently got a used 2001 and have just had the same problem. The way it was heating up I felt it was the thermostat so changed that but didnt help. It appears that air pockets are causeing the over heating. On the thermostat houseing is a bleeder vaule which you can use to get the air out. It takes a little time to get all the air out but once I bleed the system out it seems to be fine now. Hope this helps
Jan 03, 2009 | 1999 Oldsmobile Silhouette
Mopar Performance Dodge van/wagon - full size belt, lap buckle half. 1992-93-94, 1994 Logo
74 people viewed this question
Top Mopar Performance Clothing Accessories Experts
Da Doc
ray gallant
Are you a Mopar Performance Clothing Accessory Expert? Answer questions, earn points and help others
