Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Kenmore reset button showing - Kenmore 25512/ 25513 Progressive Canister Vacuum
Kenmore vacuum just died
Sorry about that . Before you bury it see if there is a reset button you can push to reset it. Most Vacs have reset buttons. Check electrical wires and plugs to make sure they are ok. Is the plug outlet you plug it into working. These are things that you can check. did it die or did you break a belt. Does it try to start but won't.If I could see it it would be easier to know but these are just ideas. Good Luck.
Feb 04, 2017 | Kenmore Vacuums
I have a kenmore progressive vacuum with a belt reset button that trips out everytime you try to vacuum. It does it in about 5 to 10 seconds. Can I bypass the reset button or can you help me determine...
A lot of times the reset button is tripping because there is a problem. The problem could be with the brush roller in this case. A lot of times I see this unit for repair and the end of the brush is so compacted with hair and debris that it has also started to melt. This will also "fool" the reset and trip off. If you are near a service depot try there, or try sears parts if you need to have the brush roller replaced.
Bypassing the reset button is not advisable on any machine.
Nov 03, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
I've had my Kenmore Progressive canister for at least several years and never had a problem. Now, the carpet head brush does not rotate, it's not getting the connection unless I push down maintaining...
Hi, try pushing the reset button with a pen or paper clip. If that doesn't work, the motor may need to replaced. If the reset button is stuck, if the reset button is stuck, use a pair of tweezers to pull it back out......
Secondly, your belt can also be broken or has come off the pulley. Remove the bottom plate and investigate.
Sep 19, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Vacuum will not turn on
Kenmore Model 116, behind the Vacuum cleaner there is a Motor Reset switch which you need to press.
1. Make sure the Vacuum Cleaner is unplugged.
2. Press the reset button gently in with a pen.
3. Plug back the Vacuum cleaner and it should work.
Jan 31, 2009 | Vacuums
Kenmore 116 bagged canister vacuum
something is jamming the brush roller, or the bearings are seised
Aug 08, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore 35913 Progressive Vacuum with Direct Drive
If you push the reset, it should push in and if nothing happens, then there is a problem with either your cord, switshes or motor.
May 29, 2008 | Kenmore 35912 / 35913 Progressive Upright...
Kenmore 116.31912100
I went to sears.com and the diagram for this model doesn't show any reset. You could have a switch that has gotten too dusty ans isn't working or the motor for the brush roll maybe bad.
Apr 08, 2008 | Vacuums
Direct Drive System on Kenmore 31913 Vacuum
you need to reset it on the front. overload reset button
Oct 29, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore direct drive will no longer self-propell
There may also be a reset button. If the brushes get stuck the unit can shut off power to the brushes to keep a total melt down from occurring. The reset button should return power in these types of vacuums.
Aug 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
16 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
