Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
Cub cadet lt 1018 elec. pto wont engage
I pull the engage switch i hear a sound, the engine revs down about 1 second, then it doesn't engage. sounds like it wants to engage but then doesn't. any suggestions?
5 Suggested Answers
  • 130 Answers
SOURCE: electric pto won't stay engaged on LT 1045
you have a shortage or your clutch is going bad
Posted on Jul 18, 2009
  • 61 Answers
SOURCE: Cub Cadet 1641 PTO problems
bad switch.
Posted on Sep 06, 2009
  • 16 Answers
SOURCE: Cub cadet lt 1050 electric pto want engage??????????
make shure pig tail is hooked right
Posted on Oct 17, 2009
SOURCE: electric pto clutch will not engage garden tractor -cub cadet gt1
the electric clutch jhondeere won,t engage
Posted on Apr 30, 2010
How can i fix the pto on my cub cadet lawn tractor?
if the engine didn't shut off as well when you bounced out of seat , you 4 sure have a fault in the seat switch , im under the suspicion that seat switch has two contacts one is 4 engine and one is 4 pto
Aug 24, 2015 | Cub Cadet Garden
PTO WONT WORK on myCub cadet ride on mower LT 1045
i seems you already found the cause its a electrical problem look at all the wires you have a loose connection some ware the wires also like to break where they go into the clutch
Jun 28, 2012 | Cub Cadet Garden
How does the PTO on a cub cader LT 1042 operate?
Sounds like the anti rotation bracket is not engaged in the side of the electro magnetic clutch, there will be a bracket or plate or bolt fixed to the chassis that engages into the outer edge of the clutch to stop the whole unit from spinning
May 15, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Jul 06, 2010 | Cub Cadet Street Sign- tractor lawn riding...
CubCadet 1554 - won't start!
If you hear the PTO click when you turn the ignition on, sounds like the PTO button is pulled out like you were engaging the blades. The engine will not start if the PTO button is pulled out....
May 07, 2010 | Oregon Scientific Electric PTO Clutch for...
Cub cadet lt 1018 blade will not engage when i pull knob up
It sounds like the PTO is not engaging. This is the pulley on the bottom of the crankshaft and the belt for the deck goes around. It may be time to buy a new electric PTO to solve this problem.
Go to www.precisionope.com. and put your information in. you should find a part number you need there.
Sep 28, 2009 | Cub Cadet Street Sign- tractor lawn riding...
PTO switch shuts down tractor
if the pto bearing is locked up it will stop a motor dead this is a common problem. You will have to get a new clutch assemble. The other thing that it could be is the deck has a locked up spindle.
Aug 19, 2009 | Oregon Scientific Electric PTO Clutch for...
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
879 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
