Question about Bialetti Mukka Express
Valve explodes I have had my Bialetti Mukka Express for about two years now. It often leaks and can never work out why sometimes it doesn't. I have replaced the valve once after the original one that came with the new pot exploded, hit the ceiling and sprayed hot coffee round the kitchen. Now the same thing has happened about a year later with the next valve - luckily no one was in the room at the time! Why does this happen?
SOURCE: Mukka Express spits out coffe from the screw section & steam valv
it did that to me too, so I reduced the amount of milk to the indicated level inside. No more mess after that.
Posted on Feb 18, 2009
ginko
  • 19396 Answers
SOURCE: coffee has started becoming weak
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on May 22, 2009
SOURCE: bialetti mukka express
First off, the best milk for foam is skim milk (0% fat). The higher the fat content, the less foamy your foam will be.
The foam is created by the steam/hot coffee from the lower part being forced through the doohickey and into the milk. That means that if the coffee itself isn't "perfect", the foam won't be "perfect". I've found that using different types of coffee (e.g. different grinds) or filling the coffee bin to different levels results in more or less steam/pressure being passed through, so the foam is better/worse. For example, if I put too much ground coffee in the bin or use too fine a grind, it blocks the water/steam that's going through the coffee, resulting in less coffee and weaker coffee, and also resulting in less foam.
Posted on Jun 04, 2009
nethload
  • 22 Answers
SOURCE: Espresso irregularly spurts out the center post
could it be that the gasket is oversized and it covers the small holes ?
Posted on Oct 28, 2009
SOURCE: Each time I use my
Try turning down the temperature. Also make sure there is no coffee left around the edge of the joining surface. This worked for me.
Posted on Feb 13, 2011
Muka express bialetti leaking
Easy!! Not making coffee or cappuccino, go to Starbucks less issues LOL
Apr 10, 2013 | Bialetti Mukka Express
The pressure valve on my Mukka Express doesn't pop up. Instead after 10 minutes the valve is forced off. I rinse it really well and have even put it in boiling water. How do I get it to pop up?
I have the same problem. I cleaned all the parts, changed the pressure valve, cleaned the gasket, filters, everything. I hear the steam escaping from the overflow valve and if at that point I manually pull the valve up, then it does (barely) pop and steam the milk, but not as well as it used to.
Jul 25, 2011 | Bialetti Mukka Express
I cannot unscrew the top of the Mukka Express machine from the bottom!
If the bottom is screwed too tight on the top, you could try to warm the with hot water and cool the bottom with cold. This could help to expand the top and make it easier to unscrew.
May 23, 2011 | Bialetti Mukka Express
I was looking for instructions for a Bialetti Mukka Express ;and also does this unit make espresso?
Here is the owner's manual. Also, by filling the filter with espresso grounds and using water, you are making espresso. It only becomes cappuccino by adding milk.
http://www.google.com/url?sa=t&source=web&cd=5&ved=0CEcQFjAE&url=http%3A%2F%2Ffantes.com%2Fmanuals%2Fmukka_express_manual.pdf&rct=j&q=Bialetti%20%22Mukka%20Express%22%20owners%20manual&ei=JdWATp7uLcu4tge7prWNAQ&usg=AFQjCNEIi9J9flq7TmgLWUYOiLF4KatH3g&sig2=UqfzIzEfVCpfZv60t1wClg
Mar 30, 2011 | Bialetti Mukka Express
Very rarley froths, is it worth buying a new valve (which I have just blown)?
To replace the valve and have it repaired may not be worth it. Just buy a new one. Repair cost could be expensive, since it does not function well (rarely froths).
We cannot be sure as to its usability.
Nov 08, 2009 | Bialetti Mukka Express
Bialetti mukka express
Apr 12, 2009 | Bialetti Mukka Express
Mar 08, 2009 | Bialetti Mukka Express
Jan 24, 2009 | Bialetti Mukka Express
Mukka valve broke
HAVE YOU TRIED SYDNEY?
Dec 07, 2008 | Bialetti Mukka Express
Bialetti Mukka Express Logo
48 people viewed this question
Top Bialetti Coffee Makers & Espresso Machines Experts
Ross Keen
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Pennywhistler
Pennywhistler
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
