Question about Scotsman Ice Maker 600LB CM3 30inW Commercial Cubed Machine
Scotsman 17-2887-01 CM3 - Scotsman Ice Maker 600LB CM3 30inW Commercial Cubed Machine
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: scotsman 500 cm3 ice machine
Remove all molex connections and check for corrosion. Clean the connections and retry.
Posted on Mar 01, 2009
  • 112 Answers
SOURCE: On our Scotsman cm3 the
These units have a real problem with the bin controls. I can't begin to tell you how bad. There are two - for lack of a better term - paddles - that are basically just pushed into the left and right side of the drop area that have small lenses in them with a low level beam that when broken indicates a full bin. You have to reach in from under the bin opening and feel to the left and right, pull the paddles toward the middle and there should be enough slack on the wires to get a good hold of them and clean the lenses with a Q-tip soaked in grapefruit juice. Pop them back in and try them - if that doesn't work (and sorry but most of the time it doesn't) then they will have to be replaced.
Posted on Dec 11, 2010
TheMobilian
  • 8220 Answers
SOURCE: how do i check for
First check to see if the bulb of the TEV is secured and insulated well where it can sense the temps and open the valve correctly.
The tech manual
locale of discharge thermister
Page 20 tells how to check
Let me know Kimosabe what yall come up with
Posted on Apr 16, 2011
Scotsman ice machine
Check the water inlet valve water seeping through valve should be running over into bin. Replace or rebuild valve. the machine should have slowed down on production of ice also.
Jul 17, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Why Scotsman CM3 ice machine shows diagnostics water problem?
should you have any questions, Thanks John Tripp Appliance 911
First let's look through the different service manuals. CM3 Water level sense diagnosticsDOWNLOAD
Head Pressure Control Kit - CM3DOWNLOAD
Reduce Air in CM3 ModelsDOWNLOAD
Replacement of the CM3 controllerDOWNLOAD
Service Handbook to 2007 - CM/CM3DOWNLOAD . I am here should you have any questions, Thanks John Tripp Appliance 911
May 15, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman cm3 does not harvest
First i need the model number CM3 is a controller number and is it a blue or black controller. then i will be able to help you.
Feb 11, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
your sump level control sensor is not reading the water level drop to go in harvest.you can do a self check test or replace the sensor(little blk box) could be wire harness. check to makeure your water value is leaking through
How do i check for low discharge temperature or maximum length freeze cycle on a scotsman cm3 model#hd30b-1a
The tech manual
Apr 16, 2011 | Scotsman Ice Maker CM3 30inW Cubed Ice...
We have four Scotsman Ice Makers. The curtains are beginning to turn a little green. What is the approximate cost of replacing these curtains. How much per curtain?
Unless they are terrible you can clean the curtains. What you do is put icemaker cleaner in the icemaker and run it through a cycle. I don't know how much the curtains cost.
Sep 28, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
What do i need to do to get the scotsman cm3 connected and ready to operate
http://www.scotsman-ice.com/?xhtml=xhtml/sct/us/en/homepage/default.html&xsl=homepage.xsl
start with this web site and click on Sales and Service. Look for you specific model manual and it will have all the install info. Hope this helps.
Jun 12, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman 500 cm3 ice machine
Jul 17, 2008 | Scotsman Ice Maker 600LB CM3 30inW...
Refrigerators Logo
183 people viewed this question
Top Scotsman Refrigerators Experts
t-stat
Level 1 Expert
john h
John Tripp
John Tripp
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
