Question about Mitsubishi WD-65732 65" Projection HDTV
Fan codes for mitsubishi
Status light blinks 3-7 red model #wd65735
  • 375 Answers
SOURCE: Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
Posted on Sep 12, 2007
  • 179 Answers
SOURCE: I have a Mitsubishi WD-62525.
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Posted on Nov 17, 2008
ladywinn
  • 5138 Answers
SOURCE: Mitsubishi Model 52525 flashing red status light
Have they replaced bothof the STKs in TV?
Posted on Dec 22, 2008
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Posted on Jul 16, 2009
SOURCE: Red blinking status light on DLP Mitsubishi TV
how do you get the tv back on when the light keeps flashing
Posted on Sep 10, 2010
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Mitsubishi Televison & Video
Wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 25, 2012 | Mitsubishi WD-60737 TV
Error code 13 on mitsubishi wd52628
wait for the light to go out then press power. Then if it doesnt power up hold the menu and the Device/input buttons on the set both in together for 5 seconds the light will blink a series of blinks pause briefly then blink another number of blinks then pause then it will repeat the same two digit blink sequence a few times . Let me know the two digit blink sequence.
Aug 29, 2012 | Mitsubishi WD-52628 52" Projection HDTV
What does it mean when the status light is blinking red on my mitsubishi wd-62526
When the status light is blinking push the device and menu buttons on the tv at the same time and hold for 5 seconds or more. The red light will then blink a code. It will blink like 3 times, pause, then blink like 5 times. That would be a code of 35. It may blink one time long, then two short blinks. That is not a code blink but indicates another problem. Do a search for the service manual for your tv on the internet and look up the code. Sometimes it is as simple as a dirty fan that won't turn any more. But by knowing the codes you will know if you need a technician or if it is something simple.
Oct 07, 2011 | Mitsubishi WD-62526 Projection TV
I have a mitsubishi 735 series dlp tv. Has red blinking status light. The error code was 4 blinks then two blinks. Do you know what is wrong with it?
That's the error indicating the lamp/ ballast fan has stopped working. You can get the Mitsubishi lamp / Ballast fan 299P321010 used in the V39 series DLP televisions. It comes with installation instructions and is available from www.tvrepairworld.com under the Mitsubishi DLP parts category.
Aug 25, 2011 | Mitsubishi Televison & Video
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
Note:
and read the code.
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Light on Mitsubishi SL4SU Projector
To jmatthews
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
Take care
Oct 28, 2008 | Mitsubishi SL4SU ColorView Multimedia...
Mitsubishi WD-65732 65" Projection HDTV Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
