Question about Sharp LC32D62U 32 in. LCD HDTV
Sharp TV Component - Sharp LC32D62U 32 in. LCD HDTV
No video from AV1 channel connected to a Toshiba DVD player via Component to Sharp Aquos TV via HDMI. Audio is fine via Optical cable.
Usually you cannot mix and match sources and outputs. In other words, if you're using component to connect from DVD player to a receiver, you have to also use component to connect from receiver to TV. Input and output MUST be the same - both HDMI or both Component.
Apr 19, 2015 | Sharp Audio Players & Recorders
Sharp TV problem LC-40E77UN Sharp Blu Ray
PLEASE place your question in the appropriate forum/section under TELEVISIONS, because this is the VACUUM section. That way, someone knowledgeable about your problem can help you.
Oct 19, 2013 | Televison & Video
Sharp power
Your TV is not equipped to handle component input.
Oct 25, 2017 | Televison & Video
I'm getting sound from my sharp tv when hook uo to my blu-ray player
If I understand when the blu-ray player is connected to the set you get the TV sound or what? If properly connected by way of a set of rear audio/video or component jacks to the same on the TV--you should if change the TV input to that location see the blu-ray and hear sound it sends out.
Component, composite, or what is the hook up between the two units?
Dec 05, 2012 | Sharp LC70LE640U 70-inch LED/ LCD TV
What is the screen resolution to the sharp 32C540 ?
480i is the highest resolution of your tv. The tv has composite, s-video and component inputs in the back. The manual states that with component connections are dvd compatible allowing you to enjoy the highest quality image playback than using s-video. Dvd's resolution are 480i or 480p. I'm guessing it's more 480i than 480p since the tv is a crt tube tv and does not have any of the digital inputs for higher resolutions.
Jul 06, 2011 | Sharp 32C-540 32" TV
I need the code for an RCA remote model RCR311W for a sharp tv
Hello
Codes for Sharp TV with RCA RCR311w are
Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
Direct code entry method
1. Manually turn on the component
you want the remote to control.
2. Locate the enclosed Code Lists.
Find the list for the component you
wish to program. Find your
component's brand. You will see a
listing of four-digit codes for each
brand. If your brand isn't listed, use
one of the Code Search methods to
program the remote control. (Refer
to pages 7 and 9 for Manual and
Auto Code Search methods.)
3. Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you
wishto program. The illuminated
ON•OFF key turns on and
remains on. If you release the
component key at any time
during the Direct Code Entry
procedure, the illuminated
ON•OFF key blinks four times,
and the process is exited.
4. While holding down the
component key, consult the Code
Lists for the four-digit code that
corresponds to your component's
brand and use the number keys
(0-9) on the keypad to enter it.
While you are pressing the
numbers, the illuminated
ON•OFF key turns off.
5. After the fourth number is
entered, the illuminated ON•OFF
key turns on. At this time, release
the component key. If the
illuminated ON•OFF key turns
off, you have entered a valid code
and have followed the correct
procedure for Direct Code Entry.
If you enter a code number that is not
in the Code Lists or you do not follow
all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks
four times when the component key
is released. This is an indication that
a programming error has occurred.
In that case, repeat the Direct Code
Entry process from step 3.
of each key, be sure to keep the remote
pointed at the IR sensor of the
component you are currently
programming the remote to control.
6. To confirm that the component key
is programmed with the correct
code for maximum functionality,
test the component. Attempt to
control a variety of the
component's functions with the
remote. If some of the features of
your components do not work, try
programming the remote with a
different code in the list until you
find the code that allows the
remote to control the majority of
your component's functions.
Different codes can provide
different levels of functionality
OK
Mar 04, 2011 | Televison & Video
Want to see a free online manual for the Sharp 27J-S100 CRT TV--need to know what is the best possible hook-up (HDMI, Component, S-Video, or Composite) for pic quality. Thanks!
CRT-(Tube tv).Dosen't support HDMI cables.S-Video cable.Only on some a 27' and above.Mostly are R,Y,W RCA component cable support work best for the standard below 27" (CRT-tube-tv).
Dec 17, 2010 | Sharp Televison & Video
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
VGA to SHARP flat sreen tv
1. vga to vga cable
2. vga to dvi cable
3. vga to dvi cable, then dvi to component cable
Your tv must have 1 of the following:
- vga connector
- dvi connector
- component connector
Feb 24, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp
www.asm-service-manual.com/List/TV%20List%20ASM.htm
Oct 22, 2007 | Sharp 32C-240 32" TV
Sharp LC32D62U 32 in. LCD HDTV Logo
20 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
