Question about Kenmore Heating & Cooling
Does not seem like fan is working or blowing any air and the unit keeps shutting off.
    Problem Solver:
  • 6 Answers
I the fan isn't running it will shut off on the safety . Simple could be blocked filter worse case dead fan motor.
Posted on Jun 20, 2009
  • 230 Answers
SOURCE: weather king central air conditioner
You have done a good job under the circumstances. It could be a bad start/run capacitor as well. It carries a lot of amperage so I suggest hiring a technician to check the capacitor and the motor.
Posted on Jun 25, 2008
  • 8 Answers
SOURCE: fan blows.. no cold air... no hot air exhaust blowing
This sounds like you either need to clean or replace the filter, but if the filter is some what new you might want to take a look at the coils just past the filter, if the coils do not have a shine to them then you might want to buy some coil cleaner (i found simple green or formula 50 works great), then you will have to spray the coils with the cleaner, let sit about 10-15 min, then give it a very good rinse with warm water. After that it should work like it is brand new. Enjoy!
Posted on Mar 30, 2009
  • 340 Answers
SOURCE: my inside air conditioner fan isnt turning on whats wrong?
If the in side blower motor turns off with the out side unit normal operation if the thermostat in the auto position set for cooling If the out side unit run with out the in side unit the out side unit will be wrecked . sounds like you need service and have it cleaned for best performance . Tom
Posted on Jun 17, 2009
  • 4 Answers
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Posted on Jun 18, 2009
  • 5 Answers
SOURCE: Carrier A/C unit blowing hot air and fan not spinning
check the belt drive and refrigerant
Posted on Jul 12, 2009
My air handler keeps trying to blow but keeps stopping the outside unit is working fine, it is an Amana unit.
The most likely things, in order, are:
1) There is too much dirt, dust or lint clogging the squirrel cage fan, slowing it down and causing the motor to overheat and shut off.
2) The motor is clogged with dust or dirt and is overheating and shutting off.
or 3) the ductwork is clogged, causing the motor to overheat and shut off.
God bless your efforts.
May 11, 2018 | Amana Heating & Cooling
Ruud upnl troubleshooting
There are usually two fan switch positions.. AUTO and ON. make sure it is on AUTO.
Oct 16, 2013 | Heating & Cooling
Fan will not shut off
if you bought the t-stat at menards or any box store change it with one from a contractor they are known for this problem
Dec 13, 2012 | Goodman Manufacturing Goodman ARUF182416...
Beverage Air. Model: CFG24-1. The evaporator fan motor does not turn while unit is operating. The entire condensing unit is working, except the evaporator fan motor. When I removed the evaporator fan motor...
http://beverage-air.com/pdf/manualsbycategory/K%20Series%20-%20Bottom%20Mount%20Reach-Ins/CFG_CRG_KF_Series809-046A.pdf
The fan has a limit control wired in series that shuts the fan down until the coil temperature reaches 25*F. this prevents the fan from blowing warm around after defrost.
There is also a switch which is placed for the door to close. Either one may be defective.
Worst case is the freezer is not pulling down temperature wise.
Jan 19, 2011 | Beverage-Air CFG24 Freezer
The fan doesn't seem to be blowing and the computer keeps shutting off
i think there is problem with PSU(power supply unit)
You will have to change it as in get it replaced and then try,it will work
May 17, 2010 | Computers & Internet
My Averatec 3200 keeps shutting itself down. The
A common problem with all laptop is dust. Sounds like you have 5 years worth of dust stuck in there. You should get a can of compressed air and blow though every vent you can! You want to loosen the dust that's in there and possibly try to blow it out and/or get it closest to the vents.
After that you should take a vaacum cleaner and **** out all the dust you can!
Dust inhibits air flow, alot! Its the number 1 killer of old computers.
Apr 18, 2010 | Averatec Sotec 3200 Series Fan with...
My unit shuts down after 45minutes an blows hot air
Sounds like a bad Condenser fan motor. The fan keeps the compressor cool. If it is broke the compressor will over heat eventually and shut off.
Oct 21, 2009 | Heating & Cooling
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Heating & Cooling Logo
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
