Question about HP Pavilion dv6000z Notebook
Battery not charging
Hi for some reason the battery of my HP is not charging the computer says its charging but i have been using it for an hour and no charge or decrease it stays at 5 percent why
    Scholar:
  • 149 Answers
The battery is probably dead. If the battery is two years or older, it may be time to replace the battery.
Also, if you have a voltmeter, confirm that the p/s is supplying you with the correct voltage.
Good luck
God Bless
-Carlos:
Posted on Jun 20, 2009
I have new laptop how many hour battery charge first time
First Time Charging
  • The amount of time it takes for your battery to fully charge depends on many factors, like your battery type and operating system. Many newer laptops will charge in 15 to 20 minutes, while others can take a few hours.
    When you're charging your battery for the first time, charge it fully before using your laptop. You may have to go through a battery cycle a couple times before your battery begins performing at its maximum capability. To do this, charge your battery fully, let it discharge to about five percent, and then fully charge it again
  • Read more: For How Long Should One Charge a New Laptop Battery? ' eHow.com http://www.ehow.com/way_5261076_long-charge-new-laptop-battery.html#ixzz1GTAFQEz9
    Mar 13, 2011 | Acer Computers & Internet
    My battery always stays charged, so why is my laptop telling me that i need to replace my battery?
    Hi,the reason why your laptop is telling you to replace Battery is,you have killed your battery without knowing by Charging it always,since you have constant power supply,you should at least after getting a new Battery,discharge it four to five times a week longer life of battery,by these i mean,unplug cord from mains let power drain to 5% or 10% before charging again while working and if fully charged and you are not making use of it disconnect and if you want to make use of it use battery instead do not connect immediately to mains until power drains from battery.Just like your mobile phone,you only charge it when need be(ie. when Battery is Low).
    Jan 01, 2011 | HP Pavilion DV7-1020US Laptop
    Im tommy from nigeria,i use hp camera cb350 but it's a battery killer.i use energizer 2500mph rechargeable.after charging the maximum shots it takes is between 5 to 10,where as some of my friends takes...
    Hi, Below are the tips to you : Digital camera use high current to make it works. Your 2 units battery 2500 mAh are normally worth for your camera. Your battery will get its full capacity after charged for 13-15 hours from designated charger ( I supposed you to use energizer charger).In your camera set your flasher to auto mode. This will save the power rather than use the flasher manually / all time. If after fully charged the battery and you still get the same performance. You may have wear down battery and need replacement. New battery required 24 hours charging before use at first time. Now install your new batteries. If you still get same problem, you've got problem with your camera internally.
    Dec 04, 2010 | HP CB350 Digital Camera
    My kin-1200 ap doesn't charge the battery properly.
    The reason for this is that the UPS, is unable to efficiently charge those BIG batteries, you see they generally only charge at a low rate, anyway, of say 10% - 15% capacity, of the-battery-usually-charged. Now with these BIG 40 Amperes by 2, well, there simply isn't enough "Juice" to charge them up... (Oh it might do in a month or so)... from that UPS's Charging Circuit. You will most likely have to rig up some other higher rate charger for those BIG batteries. OR modify the charging circuit IN the UPS. They need to be charged at about 1 Amp or maybe more. See it is simply Charge over Time... 40 amps at 1 Amp will take 40 hours.. 40A at 2A = 20H & so on. If only 1/2 flat 2A over 10hours.
    Feb 07, 2010 | Powercom King Pro UPS System
    Is this hp pavilion dv1000 battery a cheap one?
    From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
    Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
    Rating: rate4.gif
    Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
    8800 mAh 11.10V C $ 79.69
    Availability: In stock
    Notes for charging Hp Pavilion dv1000 Series battery :
    1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
    2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
    3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
    4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
    5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
    6. It is normal for HP laptop battery to become warm during charging and discharging.
    7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
    Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
    Laptop battery wont charge
    If you want to make sure of its state, be patient and give it enough time to charge. It might take 3-to 4 hours withe the computer is turned off, and a dozen hours if the computer is beig used. If after a significant number of hours, it is still at 0mAh then either the charging circuitry is defective or it is the battery that is defective (cannot hold the charge).
    Hope it helps.
    Aug 29, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
    Bought a new battery and it wont charge, says on AC power
    Take the Battery back Its defective , New batteries should charge for 18-24 hours, and the computer should tell u that it wont run till the battery is fully charged.
    Jul 22, 2009 | HP Compaq Presario V2000 Notebook
    HP PAVILLION DV6000 REPORTS BATTERY NOT CHARGING
    Your battery is dead when it no longer will hold a charge. Replace your battery.
    Jun 02, 2009 | HP Pavilion dv6000z Notebook
    The battery won't charge so we bought a new battery, but when the battery got low we tried to chagre it and it won't charge, os we tried another charger but it seems as though we just can not charge a...
    Hi Tracy!
    Okay, there are a variety of reasons why this might happen but the best way to find out is to simply take out the battery but leave the AC adapter plugged in then turn on your computer.
    -IF THE COMPUTER TURNS ON: then youre in luck. kinda. your new batter is a dud and you should get a free replacement from whomever you purchased it from.
    -IF THE COMPUTER DOES NOT TURN ON: it is most likely the A/C cable. These can be bought online from the HP site or cheaper on Ebay. Although the AC cable is the most likely reason, please keep in mind it might also be a number of other not-quite-so-easy to fix problem.
    Keep us updated!
    -TJ
    Nov 30, 2008 | HP Computers & Internet
    Battery
    This IPAQ will not support 3rd party battery manufacturers. Ensure you are using an original HP battery. You usually can use the battery one time--but when the charge runs out, so does your luck.
    Most of the time you will get an on-screen warning that the battery will not be able to charge when you use a 3rd party battery. If you are using an original, you might need a new battery--they do wear out after time--too-old batteries no longer hold a charge.
    Jan 21, 2008 | HP iPAQ h6315/h6365 Pocket PC
    HP Pavilion dv6000z Notebook Logo
    53 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
