Question about DG 6019 Sunglasses
Sunglass arm hinge is broken is it able to be fixed?
Can it be taken to a welder to be fixed?
How do I remove scratches from sunglasses
If they are not too deep, use some Brasso-gently, also works on wristwatch crystals - though not mineral glass.
Jul 21, 2014 | Revision Sawfly Deluxe Three Lens Regular...
I lost left side arm of emporio armani 9282 sunglass
You can get help of the stores who are providing services to repair sunglasses. You will definitely get help and the things you need for your sunglass.
http://www.horizonsunglasses.com/Fuschia-Pink-Smoke-Classic-p/cla-fus-pnk-smo.htm
Apr 03, 2014 | Emporio Armani EA 9282/S Sunglasses
My drivers door is hanging about two inches the car was in an accident before i owned it and the drivers door was obviously worked on. the hindges seem tight but are bending the body. (my question is...
The arm you are meaning is only the door stopper and is not supporting the weight of the door. It is possible that the door hinges and door post have changed in the position/alignment after the accident. So it is ideal that the door be taken out and the tinkering done on the door post , then the hinges can be changed or fixed to alignment of the correct gap.
Mar 04, 2011 | Suzuki Sidekick Cars & Trucks
Have a scratch on one lens. Can this be taken out?
Scratches on lenses are very hard to take out. If they are buffered then it will change and degrade the optics of the lens. There are a few solutions that have been known to remove small and light scratches such as furniture polish, or cd/dvd cleaning solution.
Jan 10, 2011 | Carrera Clothing Accessories
I have sunglass from christian dior the glass a mask style, my problem is during my vication a part of the mask glass broked, and noe one can fixed this problem here in my country Libya, please help me...
hi
i am really sorry i cant help you on this becasue the part of a frame has been broken so to just fixt that piece is really tough it better you change the whole lens i think that only can be done or let do one thing can be done please specify which part is broken so that i can think of a solution
Dec 23, 2010 | Christian Dior Acapulco S Sunglasses
Wind shield wipper handle wont stay in place it broke how do you fix it
Well you can please follow the below steps -
1. Lift the wiper arm away from the windshield. If the tension spring is damaged or broken, the arm will not show resistance. If it is functioning properly, then pull the arm back until the hinge locks in a vertical position.
2. Remove the retaining nut at the base of the windshield wiper arm and pull the wiper arm off.
3. Slide the new wiper arm assembly on.
4. Tighten the retaining nut and lower the arm back down to the windshield.
Please post comments for any other help or information......
Good Luck!!
Thanks
Mar 26, 2010 | 1999 Chevrolet Silverado 1500
Acer 5315 broken hinge help!
the hinge may be under the power bar
a few screws, and are also connected to the brackets that run along the lcd,
the unit basically has to be taken apart completly
Jul 20, 2009 | Acer Aspire 3050-1733 Notebook
My Nintendo ds goes on them off
well, both of you have a broken fuse, and kgould3 has a broken hinge and screen.
1. well, the it is fairly easy to fix a broken hinge, and the screen is a bit tricky, but www.powergamingparts.com has awesome (free) repair guides that are easy to follow and with a little time and patience you can fix that in a jiffy (they even sell everything you need)
2. the fuses, on the other hand are really difficult.
a. you might just want to sell it on ebay and people make a living off fixing and reselling the product
b. if you really want to fix it, then you are going to need to resolder the F1 or F2 or both fuses
if you guys want info on it, just notify me and i will give you the details
Feb 21, 2009 | Nintendo DS Lite Console
1990 cadillac seville brake arm
You would have to take a picture and send to mcalkins3@yahoo.com to verify fix. Sadly if its that bad I imagine the rest of the car is pretty rough underneath. Technically speaking if the car is worth fixing the welder would have to be an up to date D.O.T cerfitied welder.
Sep 21, 2008 | 1990 Cadillac SeVille
DG 6019 Sunglasses Logo
Top DG Clothing Accessories Experts
Da Doc
ray gallant
Bill Boyd
Are you a DG Clothing Accessory Expert? Answer questions, earn points and help others
