Question about Eastern Tools & Equipment Electrical Supplies
I need a wiring diagram for diesel generator model DG6LE
  • 42 Answers
SOURCE: wiring diagram for Generac engine on standby generator
here is a wiring diagram for that engine:
Posted on Mar 13, 2009
protek480
  • 1723 Answers
SOURCE: i need the wiring diagram for the model 40026
Go here:
Champion Power Generators : http://www.cpeauto.com/techbulletin.php
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 08, 2009
  • 5603 Answers
SOURCE: kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Posted on Aug 11, 2009
puertobori
  • 7733 Answers
SOURCE: need wire diagram for a
Try here-->link.
Posted on Oct 19, 2010
  • 512 Answers
SOURCE: need a wiring diagram/schematic for the power output end/recepticals for the coleman powermate 5000 model pc0545305.01 generator
Couldn't get you a wiring diagram but the contact info should get you to someone who can. The other links will get the manual and parts breakdowns.
Coleman Powermate Powermate 5000W Generator
http://www.powermate.com/contact.php
http://www.powermate.com/pdfs/2007/11/12/manual_pc0105000.pdf
http://www.powermate.com/pdfs/2007/11/12/parts_pc0105000.pdf
Posted on Oct 02, 2012
Testimonial: "Thank you very much."
I need the wiring diagram on a Honda generator model eu2000i for the front cover on the inside any the wire diagram
Type maker, model, user manual in computer search engine. It will bring up sites to get user manual. In the manual, there is a wiring diagram
Dec 13, 2015 | Honda Electrical Supplies
Where can I find a service center in Pasadena, TX or Houston, TX????
YOU CAN FIND OUT ON THE YP (YELLOW PAGES) LOCALLY AND ON THE INTERNET YP.COM
Jun 17, 2015 | Northstar ETQ DG6LE Portable Generator...
ETQ generator DG4LE cut off value under tank broke and no fuel comes thru
syphon the gas out,tip it up so whats left will not come out of the hole for the shut off,unbolt the shut off and it should be part number,ETQ 17150,,,or whats on the pic
http://theportablegenerators.org/manuals/ETQ/Diesel-ETQ-Gen-178F.pdf
http://theportablegenerators.org/manuals/ETQ/Diesel-engine-DG4LE-DG6LE-manual.pdf
May 12, 2015 | Eastern Tools & Equipment ETQ DG4LE 4,900...
I have an ETQ TG60H12 6000 wt generator. It has .9 hrs because I only fire it about once a month. I've noticed a wet spot on my shed floor but was never able to determine the origin until I noticed a leak...
remove and let the tank dry out you can then get a product that you pour inside to cure the leak, cant remember the name of the product most bike shops would be able to get hold of it
Oct 23, 2013 | Northstar ETQ DG6LE Portable Generator...
Wiring diagram for generator
What generator make and model do you need a wiring diagram for?
Sep 17, 2013 | Electrical Supplies
Drawings
generator starting working but the output voltage power supply is not working
Jan 17, 2012 | Taylor Skid Mount Diesel Generator Set 30...
How do I remove the alternator on my 1998 Dodge 1500 4wd?
WARNING: DISCONNECT NEGATIVE CABLE FROM BATTERY BEFORE REMOVING BATTERY OUTPUT WIRE (B+ WIRE) FROM GENERATOR. FAILURE TO DO SO CAN RESULT IN INJURY OR DAMAGE TO ELECTRICAL SYSTEM .
  1. Disconnect negative battery cable at battery. Diesel Engines: Disconnect both negative battery cables at both batteries.
  2. Remove generator drive belt.
  1. Remove generator pivot and mounting bolts/nut. The diesel engine uses a bolt at top mounting and a bolt/nut at lower mounting. Position generator for access to wire connectors.
  1. Remove nuts from harness holddown, battery terminal, ground terminal and 2 field terminals. Remove wire connectors. A typical generator wiring harness is shown in. Wiring harness routing as shown may be slightly different depending on vehicle model and/or engine.
  2. Remove generator from vehicle.
INSTALLATION
  1. Position generator to engine and install wiring to rear of generator. Tighten all wiring fasteners as follows:
    • Battery terminal nut-8.5 N.m (75 in. lbs.)
    • Ground terminal nut-8.5 N.m (75 in.lbs.)
    • Harness holddown nut-8.5 N.m (75 in. lbs.)
    • Field terminal nuts-2.8 N.m (25 in. lbs.)
  1. Install generator mounting fasteners and tighten as follows:
    • Generator mounting bolt-All gas powered engines-41 N.m (30 ft. lbs.)
    • Generator pivot bolt/nut-All gas powered engines-41 N.m (30 ft. lbs.)
    • Generator mounting bolt-Diesel powered engines-54 N.m (40 ft. lbs.)
    • Generator pivot bolt/nut-Diesel powered engines-54 N.m (40 ft. lbs.)
CAUTION :
  • Never force a belt over a pulley rim using a screwdriver. The synthetic fiber of the belt can be damaged.
  • When installing a serpentine accessory drive belt, the belt MUST be routed correctly. The water pump will be rotating in the wrong direction if the belt is installed incorrectly, causing the engine to overheat.
  1. Install generator drive belt.
  2. Install negative battery cable(s) to battery(s).
Dec 13, 2010 | 1998 Dodge Ram 1500 4WD
Starting system wiring diagram for a 86 ford e550/100
Have you located your local Cummins Dealer for this. It should be no issue for them to copy/email a diagram. Good luck...
Jul 13, 2009 | 1986 Ford Econoline
1000 watt Yamaha generator surges when on low setting
YOU PROBABLY HAVE LINKAGE PROBLEMS ON THE CARB IS IT AUTO THROTTLE IF SO YOU MAY ONLY NEED TO ADJUST THE SETTING SCREWS GIVE ME SOME DETAILS LIKE BRAND HORSE POWER CARB BRAND AND MODEL AND I MAY HAVE THE EXACT ANSWER FOR YOU I HAVE ALOT OF SMALL ENGINE RESOURCES FOR SPECS AND DIAGRAMS
Jun 23, 2009 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Need a wiring diagram for both these pickup(not audio)
what part of wiring diagram ? and i might be able to email it to ya
May 07, 2009 | Dodge Pickup Cars & Trucks
Electrical Supplies Logo
356 people viewed this question
Top Eastern Tools & Equipment Electrical Supplies Experts
Bernie Knutson
Bernie Knutson
Level 1 Expert
wadingriver
wadingriver
Are you an Eastern Tools & Equipment Electrical Supply Expert? Answer questions, earn points and help others
