Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
Viking oven on range does not heat - Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
SOURCE: viking oven won't heat
Igniters need to be replaced
Posted on Aug 26, 2008
SOURCE: viking stove
no the termostat but the ignitor that's the part that's nest to the broiler burner. the part that ignite the flame. when you turn on the broiler the ignitor becomes red like a glow.
Posted on Dec 10, 2008
  • 42 Answers
SOURCE: Viking Range oven door does not close properly
sounds like the door hinges need replaced. order a part #PC020009 qty 2
Posted on Dec 21, 2008
bobsteelesp
  • 22 Answers
SOURCE: Have a Viking range, gas top, electric oven, neither work.
Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
Posted on Sep 12, 2009
  • 23 Answers
SOURCE: Viking 30" Range - Igniter works - but NO FLAME in oven or ranges
No pilot light need to be ignited. You may need a new ignitor. It might not be catching. If you pull the bottom oven plate off you can see the ignitor on the side of the burner and see if it is in its place or broken or just plain old. It is a simple fix. You can buy a universal ignitor or contact Viking and they will sell it to you. Its only two wires and can do it yourself if you are somewhat technical. Good luck.
Posted on Sep 18, 2009
I have an Eaton Viking stove that has a broken baking element. Is there anyplace that can supply one for me.
Amazon or direct
Amazon.com: Bake Element for Viking Range, PJ010004: Appliances
https://www.amazon.com/Bake-Element-Viking-Range-PJ010004/dp/B00OJ5VL0U
Rating: 4.8 - ‎17 reviews
Buy Bake Element for Viking Range, PJ010004: Range Parts & Accessories - Amazon.com ? FREE DELIVERY possible on eligible purchases.
Viking Parts by Viking - Factory Parts for Viking Appliances
www.allvikingparts.com/ Need a part for a Viking Range, Stove, Oven, Grill, Refrigerator or Dishwasher? We stock thousands of Genuine Viking parts.
Locate Your Viking Model and Serial Number - Allvikingparts
https://www.allvikingparts.com/Articles.asp?ID=142 What do Viking Model Number and Serial Numbers Look Like? Viking ... For Viking Open Burner Ranges and Rangetops(You have an Open Burner Range or ... Eaton Viking stove Google Search
Mar 13, 2017 | Heating & Cooling
New ignitors in Viking range oven do not heat up
You will need to measure for 110 VAC at the control switch located on the thermostat. Pleazer Appliance...
Apr 15, 2014 | Viking Kitchen Ranges
Oven will not heat over 200
oven does not heat to desired temp we have used a oven thermometer and most of time oven is at 350 but thermometer is at 275 than up to 325 and then down again to 225
Jul 09, 2012 | Viking Professional VGRC365-4GD Stainless...
Viking Oven Not Working After Self-Cleaning
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 15, 2010 | Viking Professional VGRC365-4GD Stainless...
Viking oven not heating past 150 degrees
My viking oven had same issue - I needed to replace the ceramic ignitors (if ignitors fail to heat up properly the gas valve remains partially closed). Apparently they are intended to be replaced every 3-5 years. Also inspect and clean the oven burners - mine had corroded somewhat and prevented the flame from 'moving' to the opposite side - ie only half the burner was lighting. If you are handy the ignitors are very easy to replace - one screw, two wires each.
Jan 02, 2010 | Viking VDSC365-6B Dual Fuel (Electric and...
I have a viking VGIC365-6bss I pre-heated oven to 500 degrees and now the oven door will not open.
One of the door hinges was loose. You have to lift the door by the handle to open it.
Nov 26, 2009 | Viking VGIC365-6B Gas Kitchen Range
Jan 09, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
37 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
