Question about Exercise & Fitness
What happens if somebody jumps on your head - Exercise & Fitness
95 caviler died while driving, now it will not start. Trying to start, it cranks real rough & catches hard. Any ideas?
If it has the 2.2L engine, and its has more than 60K miles on it, you may have had a timing chain jump. The tensioner for the chains breaks and allows the chain to jump time. They only last about 60-80K miles before this happens, and when it does, it usually bends valves in the head since it is an interference engine. GM knows about this and has done nothing to correct it. You need to do a compression test to confirm the problem. If it shows low compression on one or more cylinders, plan on a replacement or rebuilt head and a new timing chain set. Then either get rid of the car or plan to replace the chain tensioner every 50K miles to prevent it from happening again.
I speak from personal experience here, having had it happen twice on my daughter's 1997 Cavalier.
Oct 25, 2015 | Cars & Trucks
Bad pool header
Yeah, I hate when that happens. Did it hurt your head when that happened? The cement at the bottom of the pool can be a real head banger! Take some aspirin. That may ease the pain. And don't jump into the pool head first anymore!
Apr 16, 2014 | Gateway Computers & Internet
My craftsman framing nailer has two nails jammed in head. Is this something I can repair myself?
Yes, just disconnect the air line and get in there and dig them nails out, don't wait for somebody else to work on it. Do it yourself. The front of that gun should lift up and expose the nails coming through, pull them out with pliers, make it clear, then reload and fire it back up and see what happens, a lot of times the generic nails will clog up.
Oct 10, 2010 | Nailers 3 12" Pneumatic Air Round Head...
The headlights,radio,heater fan work but when I try to start the engine every thing goes off ,there is no click or starter sound. I cannot find the solenoid. HELP!
have you looked at the starter it or battery level, check the volts on the battery first, then have somebody give you a jump start, if it starts then you could have a loose cable wire on the battery or the terminals are dirty, if the volts are 12.5 or above and you also try to jump start it and nothing happens it is most likely that you have a bad starter
Sep 03, 2010 | 1984 Chevrolet Chevy
How to cheak my magnedo on my 19.5 briggs not getting a sprak
remove the spark plug then with the wire still attached to the plug lay it on the head of the engine and try to start the engine have somebody stand near the engine to see if they can see a spark jumping across the gap if so it's giving a good spark.if not don't panic yet it check the ground wire as if the wire is grounded it wont spark either then check the electronic ignition replace if nessesary..good luck
Apr 02, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Screen jumps and goes white. Is an ACER Aspire 5920. Under one year old. It jumps and I can see lines. It only does it occasionally. Has never been dropped. No idea why it has started to do ti???? HELP!!!...
let me know how long it takes to error happen from starting power ,there are several reason:
1-the flat vga cable from mainboard to lcd is damaged or pluged out from places.
2-graphic chipset on mainboard is damaged .
3- lcd has a problem
let me know if there is any other question
Aug 09, 2009 | Computers & Internet
Vaio pc - jumping curser!! never used the undo button so much. Heading for a breakdown. Help somebody. Please...
Please follow the steps as mentioned on the article page through the link given below to troubleshoot the Touchpad issue.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C541753
Jun 11, 2009 | Sony Computers & Internet
I purchesed a 2003 engine 3.0fwd online I had it installed the machanic did not change the timeing belt. will this distroy the upper cylinder heads and cause the engine not to start
if the engine jumps time (most likely at start up) it will bend several valves in cyl head. when this happens the engine will not start or run. the effected cyl head or heads need to be removed and reconditioned or replaced. cyl heads probebly ok but valves will be bent.
Mar 27, 2009 | 2003 Saturn VUE
Problems with yahoo mail
I Can't access my e-mail service past 3days. There is a message from the Yahoo Team that begins "Sorry for the inconvenience, you've stumbled upon a temporary problem we're having with the e-mail service". It then advises possible courses of action, all of which I've tried, including the Link to Customer Care at Error 5
Mar 09, 2009 | Yahoo Mail
Excel 2007 spreadsheets
The most likely problem is that you (or somebody) has R1C1 reference style turned on.
In the TOOLS menu, choose OPTIONS and switch to the GENERAL tab. Look for the checkbox labeled R1C1 reference style. If it is checked, this will cause your symptoms.
Just uncheck the box and click OK.
I'm not sure what happens to existing formulas. If you (or somebody) has written formulas that rely on the R1C1 style, I don't know if they automatically get updated to the regular style or not, but that should be easy to discover.
Jan 10, 2008 | Microsoft Excel for PC
Exercise & Fitness Logo
62 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
