Question about Brother MFC-3360C All-In-One InkJet Printer
Brother mfc3360 blank ink doesn't print
I ran out of colored cartridges. When I replaced them, the black ink which was half full, didn't print. It just keeps giving me the option to clean but it still won't print black. Any help would be appreciated. Thnaks!`
  • Claudio Barata
    Claudio Barata May 11, 2010
    Did you try to properly attach the black cartridge on its place and change the print settings to grayscale?
    Cheers
    Sergeant:
  • 361 Answers
Brother is good printer,there are many facitil as we can block one type colour as black or colour . look once a time in your printer option.or setting. , Is there on type colour is set only?
Posted on Jun 20, 2009
BROTHER MFC-J430W
how to reset ink absorber full with brother mfc j430w
Jul 17, 2012 | Brother Office Equipment & Supplies
Ok I have a cx8400 all-in-one Epson printer. I was out of black ink so I started using composite black. Also ran out of color ink so I bought the black cartridge and installed it. Now the printer says i...
If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement. You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expendedI have come across this issue many times and unforunately you have to replace the colour carts in order to continue to use the printer.
Sep 12, 2009 | Epson CX8400 All-In-One InkJet Printer
Brother mfc 3360 model mostly problem is no printout, pls soluti
Hi!
If one or more of the ink colors are missing from pages printed by your machine (i.e. received faxes, copies and/or documents printed from the PC etc), nozzles in the print head may be clogged, or the ink cartridge in question may not be installed correctly. Verifying that the ink cartridges are installed correctly and/or cleaning the print head may resolve this problem.
To verify the ink cartridges are installed correctly follow the steps listed below:
Open the ink cartridge cover and reinstall the ink cartridge. Open each lock release lever and push it until it clicks, and then close the ink cartridge cover.
The LCD may then display:
Did you change xxxxxx? Yes No.
The LCD may display this question for the color(s) that was replaced.
Select Yes or No by pressing arrow keys or 1/2 or "+/-" key.
After all the correct selections are made, the machine will then go into a cleaning.
The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will go back to standby mode automatically. Print the Print Quality Check Sheet and see if all colors are present:
Press the Ink or Ink Management key.
Use the up or down navigation key to select Test Print.
Press OK to confirm your choice.
Use the up or down navigation key to select Print Quality.
Press OK to confirm your choice. Press the Color key to print the Test Sheet.
If one or more of the colors is still missing from the printed page, cleaning the print head may resolve this problem. When cleaning the print head, you are given the option to clean BLACK ONLY, one of the three colors (CYAN, YELLOW, or MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then select ALL.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 25, 2009 | Brother MFC-3360C InkJet Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Kodax Eps-5 Printer want print with one cartridge
No you need functioning colour cart for black to work.
Apr 28, 2009 | Kodak ESP 5 Printer
I have mfc210c that come with three color of ink,two of them ran out which is fine because i just want to use the black ink only but it with not let me use it what can i do to use just the black ink, i...
See if there is a printer software setup option that will allow you to set B/W printing only. If not you may be out of luck. Could be this particular print device requires all colors available.
Sep 26, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 5840-CN Black Ink Not Dispensing
No, they cannot be cleaned once you lose the color completely. You'll need to replace the head.
Sep 16, 2008 | Brother MFC-5840CN All-In-One InkJet...
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Black ink not working; but colors are
Use a original brother ink cart. Do the cleaning twice. If there is no more black blocks to see, the printhead is crashed!
Aug 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-3360C All-In-One InkJet Printer Logo
503 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
