Question about Sharp AFQ100RX 10000 BTU Window Air Conditioner
Sharp doesn't turn on connection
My air conditioner on off switch is not working
No cold air compressor not turning on
Check to see if the start capacitor has gone bad - if so, replace with new one.
If that does not do it, check to see if power is reaching the windings of the compressor. If power is there then compressor is bad. If no power, why? - thermostat bad, switch ng, poor connection,
Sep 02, 2015 | Sharp CVP12PX Air Conditioner
Mercedes E300 Elegance. 1998 model. Intermittent supply to magnetic clutch on air conditioner pump. I have taken temporary supply from cigarette lighter socket. and air conditioner works fine. What can be...
You seem to have a bad connection between the air con switch and the clutch. trace the wiring backwards from the clutch to the air con switch. A wire or connection may be corroded, damaged or chafed.
Aug 28, 2013 | Sony 4.72" x 2001' Wax/Resin, TR4085plus...
My sharp comfort touch air conditioning 12,000 BTU FS-S125FX-A does not cool any more. It's running but at room temp.
Can work the external drive and you see that turns the fan but look at the compressor he works; logically not working if the fan brings the temperature domatiou.antikatestise external capacitor again if the air conditioner does not work then the compressor is stuck.
Aug 07, 2011 | Sharp Comfort Touch AF-R120EX Air...
How do I reset my energy star air conditioner? sharp energy star comfort touch air conditioner is flashing E1
Turn the ON/OFF switch to OFF and unplug the unit for 15 minutes. Then plug the uni back in and turn it ON. During that 15 minute timeout, the unit should have reset itself and reverted back to the original factory settings. If it did, you can set the controls as you desire.
Hope this helped you and thanks for choosing FixYa.
Jul 25, 2011 | Sharp Heating & Cooling
Sharp AF-M808X air conditioner. suddenly there is only fan air movement. there is no longer any cooling; turning the thermostat knob to a higher level doesn't "kick in" the coolant. but...
Simple test: the thermostat in your unit is electromechanical - unplug the unit from the mains, take it out and measure the resistance between the 2 electrical contacts, if it doesn't goes to near 0 when you turn it even a little bit then it's defective and it will have to be replaced.
If the resistance does indeed goes to near 0 then the defect is in the AC system. Another simple test: open the casing of the unit and put your hand directly on the compressor; now turn the thermostat button. If it doesn't vibrate then the starting capacitor of the compressor has failed and it will have to be replaced with a similar one.If it vibrates then the cooling circuit has got a leak and all the fluid has been lost. For that you will have to call a pro that will solder the leak shut and refill the circuit with the appropriate fluid - only he will have it, it's not sold on the customer market.
Jul 22, 2011 | Sharp AF-M808X Air Conditioner
Reset air condition
Turn the Master ON/OFF Switch to OFF and unplug the unit. Wait 15 minutes, plug the unit back in, Turn the Master ON/OFF Switch to ON. Hopefully, that 15 minute timeout allowed the electronics to reset and revert back to the original factory settings.
Hope this helps you.
Jul 08, 2011 | Sharp AF-S85FX Wall/Window Air Conditioner
We plugged in the sharp comfort touch model # AFR120BX It tripped the breaker. Now it wont turn on how can we reset the AC? Thank You
if unit trips breaker from second circuit unit has dead short possible bad compressor or controlls related problem. doesn't look good..... mike 20 year HVAC service tech
Jul 03, 2011 | Sharp Heating & Cooling
My conditioner Sharp CV-P12LX shuts down after 10 min of operation. A noise is heard in the plug reset switch as well
If you have to reset the plug then its pulling to many amps. If you don't know what else is connected to that particular line (in your breaker box) you might consider using another outlet. Increasing amps. of breaker may not be advisable without consulting an electrician.
Jan 24, 2011 | Sharp CV-P09LX Portable Air Conditioner
Sharp AFQ100RX 10000 BTU Window Air Conditioner Logo
12 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
