Question about Winter Sports
Carbuerator leaks, I put new one on, still leaks as before gas lines and all connections good
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 220 Answers
Check your float adjustment and bowl gasket.
Posted on Oct 02, 2014
Diagram "fuel system" 1984 Chevrolet G-30
I usually just buy steel fuel line of the correct size and use the old line as a guide to bend up the new one. Cut off excess and make new double flare. Much cheaper than trying to buy stock part.
Jun 11, 2015 | Chevrolet G30 Cars & Trucks
I have Ryobi weedeater that has a new Carbuerator,getting gas to the cyl.an has good fire to the plug an will not start need help bad
Make sure u r not getting to much fuel. With switch off pull string twice then turn switch with throttle cable helded wide open try to start.good luck.new dose not mean adjusted good luck
May 31, 2014 | Ryobi Garden
My 1990 Gmc sierra idles great and will run good too if you feather the gas pedal, but if you want to "get on it" the motor will act like its flooding out or something and if you don't let off the...
Is this truck carbuerated or throttle-body injected? If carbuerated, I'd put in a new carb kit...and be sure to replace the accelerator pump. Ethanol in gas today wreaks all sorts of havoc with older vehicles because the rubber and plastic parts manufactured back then were not designed to deal with the problems caused by ethanol. After rebuilding your carb, buy a product called Seafoam and add it to your gas tank at the rate of 1oz per gallon of gas. It will partially offset the problems caused by ethanol.
Sep 29, 2013 | 1990 GMC Sierra
Won't crank have cleaned carburetor changed spark plug drained gas and put fresh had it cranking at one point and could ride it but it would not idle
Will it start with starter fluid? If it will run with starter fluid then u need to rrebuild the carburator (yes again) sound like the needle is sticking or clogged
Oct 22, 2012 | Toys
Smell of gas while driving is very noticable inside of the car.
Sounds like one of the rubber hoses in the engine bay may be leaking. Could also be a leak somewhere around the carbuerator or fuel injectors.
Turn on the car and look/smell your engine bay. Look for anything that may indicate a leak or try and follow your nose. Leave running for awhle, and if you still can not find it, turn car off, and check all lines again.
May 29, 2010 | 2003 Saturn L-Series
Small hole on carbuerator opposite where gas hose connects leaks
perhaps there was a hose on/in it at one time cause it sounds like an over flow/vent.
Apr 18, 2010 | Garden
Gas line connections
The thicker of the two lines goes on top nearest to the primer ball
Mar 21, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I have fuel dripping in the front near carbuerator
Most often the leak is at the fuel line connection at the carb. Replace this gasket and check the fuel filter at the same time. Do not use thread sealant! Do not drive it with this leak!! Frankster016
Nov 26, 2008 | 1984 Oldsmobile Delta 88
Winter Sports Logo
69 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
