Question about LG WM-2277HW Front Load Washer
Lg 2010 whaser machine IE error machine stop at the moment when getting error
3 Suggested Answers
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
  • 6277 Answers
SOURCE: lg tromm washer what does IE stand for?wash
LG's 'IE' stands for (water) 'Inlet Error'.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Posted on Oct 04, 2011
Washing machine LG TR9103AEP IE error what does it mean ?
LG Top Load Washer-Understanding Error Codes - YouTube
? 2:17
www.youtube.com/watch?v=ZdoJVqFKye4
Sep 17, 2013 - Uploaded by ExperienceLG I have LG Washing machine and I tried to start it and came up with PE Error code and I ... I Can see IE OE and other error codes But Not PE.
Aug 04, 2015 | LG Washing Machines
Lg top loader ie error message, fills ok, but water running out of bottom of machine
Hi IE means Inlet Error. The machine thinks that it is not filling (as a certain time has passed without reaching level it wants).
This makes sense if water is running out the bottom.
You will need to find the leak. Maybe the tub to pump hose, or the drain pump itself. Once you stop the leak and the machine can fill in the correct amount of time, you shouldnt see the IE error any longer.
Cheer
Jun 01, 2014 | LG WD-1045FH Front Load Washer
We have an LG lds5811ww dishwasher with IE error
check for voltage at the water valve when it should be filling Try disconnecting the Water Valve outlet from the DishWasher and run the output into a bucket if all is well with the valve then remove the door panel and inspect the wires near the bottom of the door. the wires get buried in the tar like insulation causing the wires to break as the door is opened and closed.That tar like substance is one of the worst things they could of ever put into that machine causes the wires to break apart adn become brittle
Apr 30, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
IE:
area.
completely open.
Solution:
Fully open tap.
Straighten hose.
UE:
will be displayed.
Solution:
balance the load.
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
LG FRONT LOAD WASHER ERROR CODE IE
LG has general error codes for all there appliances and the "ie" error code is for the water supply. You either have a kink in your hose, water vavle shut off, or the bad problem your pump is bad.
Jul 30, 2008 | LG WD-1045FH Front Load Washer
LG Tromm 8/4 WD R8012
The manual suggests to shut the water off ,
remove the inlet hose and check the screen for blockage.
The ie message is the inlet water is insufficient.
May 22, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
IE error message
Hi, had the same problem on a LG LD 12aw5. (No water entering). Check the inlet solonoid. There should be 220V over the solonoid. I replaced the solonoid, at first, just to have the same problem. The problem was a bit more serious, the Triac driving the solonoid burnt out, and the solder on the mainboard keeping the transformer were shot to. I replaced the Triac, soldered the Transformer - and wolla - working. If water enters - but you sill get the IE error it could be the float(checks the water level). This device tells the machine when there is enough water. If this is stuck, the machine will think no water is entering. conrad_dot_dewet@gmail.com - replace "_dot_" with "." to email me.
Apr 05, 2007 | LG 24 in. LDF 7811 Stainless Steel...
LG WM-2277HW Front Load Washer Logo
16 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
