Question about Craftsman Garden
How do i replace the pull cord?
Craftsman 29cc edger 316 77237
slohry
  • 87 Answers
SOURCE: need parts for craftsman edger/trimmer 275.796432
Here's a link to sears parts website
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 10, 2009
  • 376 Answers
SOURCE: Craftsman Edger 536-797520 is leaking gas from the air filter
The needle valve is sticking open. The carb needs cleaning and diaphragm replaced. Probably best taken to a shop unless you have experience with diaphragm carburetors. Dwain
Posted on May 27, 2009
sleprocks
  • 147 Answers
SOURCE: starter rope pulled out and wont retract on
remove the starter cover and try to wind the starter rope manuly. the rope may have to be replaced if worn or broke..
Posted on Oct 22, 2009
  • 420 Answers
SOURCE: my craftsman incredi-pull gas powered
The rewind is sticking due to congealed grease, take the rewind off (as a complete unit) soak in hot strong soapy water pulling the string in and out to help flush the dirty grease out from around the pulley and spring. Once you feel it is cleaned allow it to dry and then apply a squirt or two of a dry lube like the graphite used for locks.
Posted on Mar 03, 2010
  • 1206 Answers
SOURCE: I have this Toro trimmer/edger.Can't pull the starter cord
you must take apart the cord recoil and rewind the pull string,inspect string make sure its the same thickness through out if not replace it, not too hard i believe you can do it.
Posted on Apr 26, 2010
Why when I pull the cord, the trimmer doesnot turn
Will not turn if it is clutch driven. When motor starts and revs are up it will turn provided the clutch is working correctly.
Aug 30, 2015 | Craftsman WeedWacker Gas Trimmer 29cc...
What direction does a weedeater head supposed to turn?
I have the yardworks curved shaft which is virtually identical to yours and it turns clockwise. Unless the straight shaft changes things but I do not think so.
May 30, 2015 | Craftsman 29CC Straight Shaft 4-Cycle...
How do I adjust the float to get more gas. bring the float up higher or lower the the float?
Lowering the float allows the fuel to enter. As the float rises, the needle valve is depressed, cutting off the fuel.
Mar 09, 2015 | Craftsman WeedWacker Gas Trimmer 29cc...
I cannot get the pull start cord to come all the way up to the hook
then the cord needs replaced with the proper length.measure how much more is needed then take what there is off and measure it add 2 numbers together for total needed and reinstall . then it will reach someone cut the other one off
Jan 27, 2015 | Craftsman Gas Mini - Tiller/Edger
Weedwacker overheats
air leak around crankshaft, scrap it and buy a new Stihl.
May 23, 2013 | Craftsman WeedWacker Gas Trimmer 29cc...
Craftsman 4 cycle weed wacker throwing oil
check the oil and see if its over full the carb might be leaking fuel into the crankcase
Aug 08, 2012 | Craftsman WeedWacker Gas Trimmer 29cc...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
