Question about Dryers
Microwave bulb with Model Number: 72163109300 and Series Number: 411TA14228?
Microwave bulb: Model Number: 72163109300 Series Number: 411TA14228
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave bulb
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 13, 2008
How do I change light bulb in Kitchenaid Microwave KCMS1555RSS
You will need to remove the cabinet to change the bulb, the part number is 4359741, now the bulb is part of the base so the part number is the correct part for this model. Good luck
Mar 14, 2015 | KitchenAid KCMS1555SSS Microwave Oven
Amana Microwave over the stove. Need to replace light bulb. So what is the part number?
If the model number is correct in your post and I assume you are talking about the over the range light and not the cavity light then you need 53001905 halogen bulb, charcoal 53001442 still available
Jan 17, 2015 | Amana AMV5206AAS Microwave Oven
How to change the light bulb
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
Oct 19, 2014 | Microwave Ovens
Want a part number for the light bulb that is under the microwave. Maytag model mmv6178aaw
mmv6178aaw Light bulb Found at sears parts direct. PN: 53001905 $14.95
http://www.searspartsdirect.com/partsdirect/part-number/Maytag-Parts/Microwave-Parts/53001905/0022/464/Model-MMV6178AAW/3048/0123370?keySuffixId=&productTypeId=&searchModelNumber=MMV6178AAW&blt=06&subCompDesc=BLOWER MOTOR
If the link does not work go to http://www.searspartsdirect.com and do a part number search using 53001905 then click Go.
You can do a model vs part search also using the searspartsdirect link just in case I did not get you the correct light bulb.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Maytag MMV6178 Stainless Steel 950 Watts...
Need part number and where to go for the bulb
go to sears.com go to parts research and enter you model number look at their diagram locate part number either order through them or call around locally,,, or sometimes if u can get the bulb out some local lighting stores willl stock them for cheaper , try to locate the watts and voltages on hte bulb sometimes writeen on the base of the bulb or on the part descritions hope this helps
Jan 30, 2010 | Magic Chef MCD1611 Microwave Oven
Surface and night light bulbs
If the model number you have this listed under is correct, the bulb you need is part #AP2029997, made by GE. You can also purchase these bulbs at any hardware store. They are the half sized small base, 40 watt bulbs. If you can't find 40 watt, make sure you use a lower wattage rating. If you have questions, or if the model number is incorrect, please let me know. I hope this helps you.
May 04, 2009 | GE JVM1650 1000 Watts Microwave Oven
Bulb for lmvm2055st lg microwave
Can't help with part number as it's not an Australian Model, but refer to http://us.lgservice.com/index_b2c.jsp to help you find a service location!
Jan 12, 2009 | LG LMVM2055 Convection/Microwave Oven
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
How do I replace the bulb inside the oven?
Your 'model number' is incomplete. Find the proper number and go to: http://www3.sears.com/ Enter the model number and you should be able to bring up a parts diagram to show you where the bulb is and which one you need.
Aug 21, 2006 | Kenmore 63672 Convection/Microwave Oven
Dryers Logo
16 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
