Question about GE 30 in. JGP328 Gas Cooktop
GE Cooktop burner doesn't click or light.
The right front burner on my GE cooktop (JGP328WEC2WW) does not click or ignite.  How do I get to the spark module to replace it?
  • cailinmullin Jun 20, 2009
    Is there something else that needs to be done to remove the burner heads, other than removing the screws in the tops of them?  Thanks very much for the information.
  • 999 Answers
Remove all the burner heads and lift the top. Sometimes easier said than done. How do you know it is the module? It could be a cracked insulator on the ignitor. To verify you can swap two of the connections on the module and if it lights then it is the module.
eric
Posted on Jun 20, 2009
  • Eric Duda
    Eric Duda Jun 20, 2009
    There might be screws under the front above the door but I figured you had already seen those.
    Eric
Cooktop model JPG933BEC2BB right front igniter quit working
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
May 12, 2011 | GE 30 in. Profile JGP933 Gas Cooktop
Stove top gas does not click and spark to light burners
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
heatman101
ncnm
Sep 25, 2010 | GE 30 in. Profile JP938SCSS Electric...
Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
the very first thing i would do here is to check the ignitor itself
under the head cap you should see two screws, once those are out you will be able to lift the burner plate, lift the burner plate, you will see, or should see the ignitor, and the wire.
i check this for voltage by unplugging the ignitor and olding the wire close to a ground, the metal body is good. Turn on the ignitor, becareful it is live. yhou shgould see a spark comming from the wire
if not check to make sure that wire is in position and on the spark module
if you do see a spark this way, just order the replacement ignitor
and install it when it arrives
appliancepartspros.com
part number AP3191250
Oct 17, 2009 | GE 30 in. JGP328 Gas Cooktop
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
GE 30 in. JGP328 Gas Cooktop Logo
551 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
