Question about Sony Bdvn890w Bdvn890w Bluray Home Theater System
Bdv-n890w and protect and push pwr - Sony Bdvn890w Bdvn890w Bluray Home Theater System
I ha e a sony BDV-E770W Blu-ray disc home theater system and when you press the pwr on button it comes on and dispray says please wait flashes and doesn't do anything else. No sound, no menu show.
Sounds like corrupted firmware. Contact the authorized service center for Sony. or, visit this site, sony e-support. This kind of fault/s are not easly repairable by a user.
https://esupport.sony.com/US/p/model-home.pl?mdl=BDVE770W&LOC=3#/howtoTab
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 21, 2016 | Sony Audio Players & Recorders
Issue programing Motorola Remote VIP2262 with Sony Bravia Home Theater System BDV-N890W/N990W
Motorola remote control have no setup codes to Sony Bravia HTS. If you wish to get some details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name of your TV / Device, in the search box at the top right of the display window.
Nov 10, 2013 | RCA L42FHD37 42 in. LCD HDTV
Motorola remote and sony home theater system code
you may need to set it up as two devices program a code for DVD to turn the unit on and off and a program and auxiliary code so that you can control the volume then you can teach the remote to use the auxiliary volume without having to press the aux button each time
Nov 10, 2013 | Sony BRAVIA Televison & Video
Sony BDV-E370
From page 68 of this manual: "Contact your Sony dealer or local authorized Sony service facility."
Mar 02, 2013 | Sony BDV-E370 Theater System
WON'T CHANGE INPUTS
Reset your code according to the instructio manual.
2) change the batteries by new ones.
3) clean the contacts batteries with contacts cleaner
4) resolder the wires contacts batteries.
5) retight the springs contacts batteries with pliers if they have.
6) open the remote.control and clean the keypads switch, from oxide diryt, open contacts, or bad contacts with VOM.remember they must send signal infrared from SYScon Trans vs Sys receiver clean
7) Try.it
God bless you
Jul 30, 2012 | Logitech Harmony One Advanced Universal...
Sony bdv-n890w not switching inputs with Harmony One remote
1) change the batteries by new ones
2) clean the contacts batteries with contacs cleaner
30 resolder the wires contacts batteries
4) retight the spring contacts batteries with pliers for better contact
5) open the remote con. and clean the keypads switch from oxide, dirty, dust, open contacts or bad contacts test it with VOM.Remember they send signal from SYScon trans vs Syscon Receive very clean. for good result.
6) Otherwise you must go to the repair shop TV. for fix it.
God bless you
Jul 30, 2012 | Televison & Video
I have a new Sony BDV-T11 Blue-ray/Home theater system. It's worked great for the first 4 days, but now the speakers cut in and out for no reason. They do not work for any function (video, radio, audio,...
It sounds like overheating is making it go into protection mode. It fails, cools off, starts up again. make sure it has proper ventilation and you're not pushing it too hard (loud).
Feb 25, 2010 | Audio Players & Recorders
Wont power up.
My guess is in the desoldering-resoldering process...try to get back to every resoldered part you did. Be sure you returned the connectors to their proper terminals.
If you can trace the output circuit before the protection circuitry...try to get a near zero voltage. Any DC voltage appearing will trigger the protection - thus indicates red.
what else did I miss?...yeah! goodluck!
Sep 20, 2008 | Harman Kardon Audio Players & Recorders
Sony Bdvn890w Bdvn890w Bluray Home Theater System Logo
27 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
