Question about Dell Precision 340 PC Desktop
Remove motherboard - Dell Precision 340 PC Desktop
    Novelist:
  • 159 Answers
Suggest you look on the Dell site for a 'service manual' ...
Posted on Mar 30, 2016
How do i replace motherboard on compaq cq5810, model #QN656AAABA
Basic steps after unplugging from power:
1. Open case.
2 Disconnect all wires from motherboard.
3. Remove all add-on cards.
4. Remove screws holding motherboard in place
5. Remove motherboard.
6. Replace motherboard, and reverse the above steps.
Oct 17, 2014 | Computers & Internet
Tip
How to change an Am2 socket to a 939
<p>1. Connect the computer operating system and save up to five minutes waiting for the AM2. Unplug the power cord plugged into the computer and the cables for each of the other components of the computer case. <br /> <p><br /> <p>2. Put the computer case on its side on a flat surface. Unlocking the computer side panel by removing the case screws on the back wall. So remove the lid of the box that the motherboard is visible. <br /> <p><br /> <p>3. In the Annex, the power of large space in the upper left corner of the computer. Unplug the power from the motherboard. Find the positions of the rectangular, green RAM module on the right side of the fan on the motherboard. <br /> <p><br /> <p>4. Slide the plastic lock down on both sides of the RAM module and remove the module from the motherboard. Repeat the process if necessary, if the computer two or more RAM modules. Find the card with the lower left corner of the motherboard. <br /> <p><br /> <p>5. Remove the screw holding the end of the metal rod of the expansion card on the back of the computer. Pull the card and remove them from your computer. Repeat the process if you have two or more expansion cards on the motherboard. <br /> <p><br /> <p>6. Disconnect the cable from the plastic fan on the motherboard. Slide the side guides of the fan and remove fan and heatsink metal AM2. <br /> <p><br /> <p>7. Pull the handle to the right of the issued AM2 processor. Pull the CPU and the motherboard removed. Remove the screws in the corners of the plate and slide the motherboard, right. <br /> <p><br /> <p>8. Lift the motherboard of the computer case. Place the socket 939 motherboard inside the chassis and drive expansion ports and power with the holes on the back of the case. Press the board to stick to the left and the screws on the motherboard in place to replace. <br /> <p><br /> <p>9. Set the Socket 939 processor socket on the motherboard and reconnect all processor pins on the base contact. Slide the locking arm and spread a layer of thermal cooling of the processor with the applicator stick. <br /> <p><br /> <p>10. Connect the power cord and insert the RAM modules and expansion cards for the new motherboard. Put the lid side of the computer and reconnect all cables. <br />
on Jun 22, 2011 | Computers & Internet
Tip
How to Remove a AMD Processor
<p>Removing a processor AMD is a work that can only be done with a screwdriver in less than 30 minutes. The processor AMD is a central processing unit (CPU) with 939 pins, which are connected to the motherboard. Removing the processor is an issue to withdraw from the motherboard with your hands after you remove the heatsink from the chip.<br /> <p> <br /> <p>1. Turn off the computer and unplug the power cord before removing the AMD processor. Unplug the connector on the back of the computer case and remove the screws, the lid of the computer, in the case with a screwdriver.<br /> <p><br /> <p>2. Slide the computer cover and set aside. Pull the cord that connects the heatsink fan on the motherboard with one hand.<br /> <p><br /> <p>3. Lift the lever on both sides of the fan heatsink, so straight up and remove the plastic clips on the sides of the sink on the motherboard.<br /> <p><br /> <p>4. Pull the heatsink and fan on the motherboard and set it aside.<br /> <p><br /> <p>5. Lift the AMD processor motherboard and carefully remove it from the computer.<br />
on Jun 21, 2011 | Computers & Internet
How do i safely remove the cable that attaches to the motherboard on my toshiba laptop
Toshiba satellite motherboard removal.
A motherboard is usually replaced for one of two reasons. You either replace a motherboard because it has gone bad, or you replace an older motherboard with a new or upgraded motherboard. In either case you will have to completely disassemble your laptop to even gain access to your motherboard. Fortunately, the Toshiba Satellite laptop can be completely disassembled even if you don't have a lot of technical knowledge.
Turn off the laptop, disconnect the power cable, remove the battery pack and disconnect any miscellaneous cables and peripheral devices. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Attach an antistatic wrist bracelet to prevent shock from static electricity. Static electricity can harm your computer's internal parts. Place the laptop face down, and remove the single Phillips-head screw attached to the hard drive cover. Remove the hard drive cover, then set it aside. Remove the single Phillips-head screw attached to the wireless card/memory cover. Remove the cover and set it aside. Slide the hard drive out of its compartment. This will disconnect the hard drive from the computer. Set the hard drive aside very carefully. Push on the ejector tabs on either side of each RAM module. Slide the RAM modules out of their compartments at a 45-degree angle. Remove them from the laptop and set them carefully aside. Disconnect the antenna cable from the wireless card, and then lift the wireless card out of the laptop. Remove the four retaining screws from the modem card. Lift the modem card slightly out of the laptop, and then disconnect the modem cable from the motherboard. Set the modem card aside. Remove the single Phillips-head screw securing the DVD/optical drive. Slide the DVD drive out of the laptop's frame and set it aside. Remove all marked screws from the bottom casing of the laptop, and then place the laptop face up. Open the laptop as far as it will go. Use a small flathead screwdriver to pry up the keyboard bezel. The keyboard bezel is a small plastic strip sitting between the keyboard and the LCD display. Remove the two Phillips-head screws securing the keyboard in place. Lift up on the keyboard and disconnect the keyboard's ribbon connector from the motherboard. Remove the keyboard from the laptop and set it aside very carefully. Close the laptop. Place the laptop vertically so the LCD display hinges are face up. Remove the two Phillips-head screws from the hinges. Set the laptop down and open the laptop as far as it will go. Remove the four Phillips-head screws securing the LCD display. Lift up on the LCD display, and then disconnect the video cable from the motherboard. Remove the LCD display from the laptop and set it aside carefully. Disconnect the DVD control board cable, the touchpad cables and speaker cables from the motherboard. Disengage the plastic latches on the rear of the laptop casing near the hinges, and then remove the top casing from the laptop's base and set it aside. Remove the two Phillips-head screws securing the CPU fan and heat sink in place. Disconnect the fan cable from the motherboard. Remove the fan and heat sink from the motherboard and set it aside. Remove the single Phillips-head screw securing the motherboard to the bottom laptop casing. Disconnect the USB port connector from the motherboard and remove the jack from its housing. Lift the motherboard from the bottom laptop casing and very carefully set it aside.
Hope this helps.
Dec 13, 2012 | Computers & Internet
A friend wants me to replace the motherboard in her HP Pavilion A4313W. She has the new motherboard, but no idea how to take the old one out and put the new one in. Any ideas?
If your friend is not that familiar with computer parts, then it is not advisable for her to change it herself. But if she wants to, she can try this. Here is a video on how to do it:
May 28, 2011 | Computers & Internet
On Starting Getting a continuous solid beep. All hardware currently equipped moved from an Asus motherboard. Would not boot formatted drive and reinstalled windows 7. I can now run and work on windows but...
Locate the speaker on the motherboard.
It is a small gadget plugged onto the motherboard.
Hold from the connector (shown on the left side of the picture) and pill to remove it.
Removing the speaker will remove the annoying sound.
Nov 12, 2010 | Gigabyte Matx Intel G31 775 DDR2-800...
I have a Compaq Presario CQ60-215DX Notebook PC. For some reason it shuts down without warning. What can cause it to do that?
Overheating...
Your going to need to clean the fan/heatsink assembly..
On the cq60, this means complete disassembly of all parts and components...in order to get to the fan properly, the motherboard will need to be removed..
Remove All screws on the underside of Laptop, Remove Covers..(hard drive,RAM,Wifi).. Pull Out CDrom....Remove the 3 screws from cdrom area.....Flip Over.. Open Screen, Pull Media Strip (above Keyboard) Away from Laptop... Be carefull Here, There are Fragile ribbon cables attached to this on the left underside ..
Now Unscrew Keyboard Screws And Pull Keyboard away, THere's a ribbon cable here too attached to the motherboard,, Unlock the ribbon cable at the motherboard port(tab on each side pulls forward).. Remove Palmrest Screws.. Pull the Wifi Cables through the Motherboard upperside, Detach any plug/wires... Unscrew Screen Hinge Posts and pull screen away... Remove the 1 screw holding the rear strip of plastic---unsnap the plastic strip at back end of palmrest area... Pull palmrest away... Unscrew The Media Card Bay and the CDrom Port Board(left side)....
Remove the 2 motherboard screws on the bottom left side front...
Unplug the long cable port on the front underside of motherboard right in the middle....
Lift up the motherboard slightly.. pulling it up from the left rear side..... You will see the DC Jack Power Cable Right There Under The Motherboard... This Needs To Be Unplugged...--Pull The Motherboard Up About 2 inches and reach under to unplug the DC Jack Wire Port Plug...and the usb plug wire...
Now continue to remove motherboard
Flip Over And Remove Heatsink Fan Assembly... Unplug Fan... Disassemble Fan And Clean FAn And Heatsink Fins...
Nov 28, 2009 | Compaq Presario Notebook
How to get motherboard out of a hp pavilion 524w
On the outside, disconnect the power-cable, then the keyboard/mouse/video/audio/USB/printer cables.
Disconnect all the cables from the power-supply to the devices (disk, CD-ROM) and to the motherboard.
On the outside-back, remove the screws holding the power-supply in position, and then remove the power-supply.
Remove the screw holding each add-in card (audio, video, modem).
Remove each of the add-in card(s).
Remove the ribbon-cables from the motherboard to the diskette & disk-drive & CD-ROM.
Look for screws holding the motherboard to the case.
Remove those screws, and gently lift out the motherboard.
Oct 31, 2009 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
Mpga478b
have u check ur memory?... ur videocard and powersupply...thats the main problem of pc if it has no display....just try it one by one...hope it can help u
Sep 10, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
6850 Motherboard Stuck in chasis...
There is a spring-loaded retaining pin with a blue cap in the center of the motherboard. Pull up on the cap and the motherboard can be slid forward in the case for easy removal.
Dec 26, 2007 | Dell PowerEdge 6850 (PE6850SAPP) Server
Dell Precision 340 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
