Question about Sunbeam Grill Series 540
Ignitor on sunbeam grillmaster 540
Need to know how to wire the ignitor
5 Suggested Answers
  • 26 Answers
SOURCE: need new burner
www.grillstuff.com please rate me if this was any help..good luck!!
Posted on Jul 21, 2009
  • 30 Answers
SOURCE: Venturi tubes
The venturi tubes should go over the gas orifice. If the tubes were to drop off, you could have a fire outside of your grill and possibly an explosion.
Posted on Mar 04, 2010
SOURCE: Need manual for Sunbeam Grillmaster BG6522RPB
I will advice you check manualsonline.com to search for the manual of your device as requested.
Take care.
Posted on Sep 23, 2010
  • 3253 Answers
SOURCE: What size orifice do I need for 12,000 btuh burner
why not just buy the kit to convert it ?
Posted on May 12, 2012
Gas oven will not lite but thing in bottom glows do not smell gas
By "thing in bottom" Iam assuming your talking about the igniter. If you are and it is only glowing then it probably needs to be replaced. If you cant smell the gas either thats a worring sign in of itself. I would first replace the igniter and then go from there though. Let me know how it goes!!
Aug 09, 2011 | Amana Ovens
The ignitor glows but the oven will not turn on
Hello Juan,
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
I hope this helps,
Gene
Aug 04, 2011 | Magic Chef 9122 Gas Single Oven
This is aCG4TDBN (elite with no back burner) aprox 6 years old. The ignitors are starting to go bad. How do I replace them?
First, you need to determine if it is the spark ignitors going bad or the Ignition Module.
If the spark ignitor tips are covered with grease or residue, this will give them the appearance that they're failing. Cotton balls and alcohol, work well to clean the spark ignitors. Also, check the wiring from the spark ignitors back to the ignition module. There may be some wear or even a burn on the wiring. Change the battery in the ignition module. Be sure the new battery is facing the same direction as the old battery, when you install it. Before installing the new battery, check the battery holder for corrosion on the contacts. If you see any, use a Q-Tip and WD40 to remove it.
As far as replacing the ignitors is concerned, you may only have to replace the spark ignitors and not all the wiring. It depends on how the wire is attached to the spark ignitor. If it can be carefully pulled of the bottom tip of the ignitor and then si back on, all you need is the spark ignitor. If not, you'll need the spark ignitor with the wiring attached. All of the wiring, will then have to be fished back to the ignitor module.
More more info on all the parts you may need contact BBQ's Galore 800-752-3085.
I hope this helped you to troubleshoot and determine if any parts do need replacing.
Jun 30, 2011 | Barbeques Galore Turbo Elite 4-Burner with...
I have been using the grill for about a year now. All of a sudden the electronic igniter dosen't spark on all control knobs. I checked the battery and replaced it with a new one. It did not change...
First, Bud make sure the battery was installed facing the proper direction. The Positive end (+) should be facing out when installed. If that's not the problem, check the wiring from the ignition module to the each burner ignitor. One may be loose or the grounding wire from the ignitor module to the grill's frame, may have lost contact. Also, look carefully at each ignitor tip at the burners. They may have an accumulation of grease, which needs to cleaned off.
If all that doesn't resolve the problem, you will need to replace the ignitor module. You can purchase one online directly from NEX Grill http://www.nexgrill.net/ or from Factory Appliance Parts
http://www.appliancefactoryparts.com/search/index.php
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 04, 2011 | Nexgrill 720-0234 (LP)
Where do you hook up the sideburner ignitor wire to on the char-coil bbq model 463721111
The side burner ignitor wire connects to the spare lug on the main ignitior module. That one module, controls all the spark ignitors at each main burner and the side burner. When you press the button all ignitors spark at one time. I know it sounds stupid, but that's the way Charbroil's R & D designed it. I guess it saves money.
Hope this helped you to make the final hookup. Happy Grilling!!
May 01, 2011 | Char-Broil CharBroil 4637318 Grill
I installed a new 7509 ignitor on my 13 year old weber genesis gas grill and the gas does not ignite when pushing the ignitor button. I installed the ignitor with the box opening on the bottom and checked...
If the spark you see is in the ignitor box and not at the burner(s), then there's a wire loose somewhere or the ignitor is not grounded properly. Also check to see if the ignitor tips in the grill next to burner(s) are covered with grease. If so, clean them with a cotton ball dipped in alcohol. Check each ignitor wire at each ignitor , make sure they are secure,
Feb 20, 2011 | Weber Genesis Silver B Grill
I bought a floor model gas grill and the igitor is not wired ( but all the wires are there). Anyone know how i attache the wires to the push button ignitor?
the push ignitor should have a spade attachment on it for the side burner wire and the main wire end should be round and will push into the end of the ignitor.
Nov 07, 2009 | Kenmore 632 sq. in. 16324
Ignitor dose not spark on one burner
Hi. these ignitors are really easy to diagnose. all to do is inspect the wires leading from the control to the ignitor/burner assembly. if the wires are in good condition and, you know for sure that your control is fine. simply replace the failed ignitor.
May 19, 2009 | GE JGRP17 Gas Single Oven
Amana gas range will not heat in "bake" mode.
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Jan 16, 2009 | Amana AGDS902 Gas Kitchen Range
How to locate and remove oven ignitor
Will need to remove the panel at the bottom, inside of the oven.  Some have another panel under that, yours may not, to remove.  The ignitor is under that in the back middle.  Should be screws that mount the ignitor to the burner.  You may be able to remove the bottom drawer and unplug the ignitor underneath the oven and remove the ignitor.  If not you can cut the wires on the old ignitor and splice in the new one using ceramic wire nuts.  Let me know if this helps.
Oct 13, 2007 | Hotpoint RGB745 Gas Kitchen Range
Grilling Logo
56 people viewed this question
Top Sunbeam Grilling Experts
Gil Shultz
David White
Steve Pack
Steve Pack
Are you a Sunbeam Grilling Expert? Answer questions, earn points and help others
