Question about Magic Chef Kitchen Ranges
The timer on my magic chef 8114P324-60 keeps turning on and even goes off in the middle of the night.
  • 183 Answers
SOURCE: Magic Chef Oven lights and shuts off
This could be caused by a lack of air within the oven cavity, once the air is used up the flame will go out, it will then work again once it is relite, but will probably do the same again, this could be dangerous and requires on site proffesional attention. Regards Engineer
Posted on Jul 28, 2007
SOURCE: magic chef beeping
You need to replace the touchpad. I'm just getting ready to replace mine for the second time in 14 years. A bit pricey but not a hard repair to make.
An appliance repairman told me that it's possible to peel the old pad off and carefully fish the connecting wire out to the point where it plugs together. This would save removing the burners and the stovetop I'm going to give it a try when mine arrives
Posted on Aug 26, 2008
  • 327 Answers
SOURCE: oven goes on without being turned on
the control switch tripper problem that switch has to be replaced with a tripper.
Posted on Dec 15, 2008
SOURCE: Magic Chef oven won't light
Replaced the ignitor.
Posted on Oct 09, 2009
iwillfixforu
  • 619 Answers
SOURCE: Magic Chef Broiler won't turn off
If this is brand new you need to get this taken care of under warranty. Any thing you try to do to repair will void the warranty and with all the electronics on this stove you want warranty to repair. Sorry I wasn't much help but you don't want the warranty voided.
Posted on Mar 11, 2010
Ticking sound is this the defrost timer on magic chef fridge
Sound like the defrost timer. Just get unit info and grab a new one and replaced. They are very simple to do
Jun 01, 2017 | Magic Chef Refrigerators
I have a magic chef stove which has three prong and I just bought a he spectra glass top which it has four prongs could I use the three prong power cord on the glass top
tes you can use 3 prong the left and right wires go on left and right terminals on stove middle wire goes in the middle.
May 14, 2016 | Magic Chef Dryers
Magic Chef electric dryer YE20HN3 doesn't stop automatically. Timer? Just keeps going and going.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Yes, it sounds like a bad timer...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Aug 23, 2010 | Magic Chef Dryers
Magic Chef refigerator/freezer stopped running
if you said stop running id assume that there is no power?? even with good electrical input..
for that instance, better check.charred cables.. if not there maybe a problem with timer itself..
Nov 05, 2009 | Magic Chef CTB1922 Top Freezer...
Our magic chef oven f1 code keeps coming on
MAGIC CHEF
Range/Stove/Oven Fault Codes
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Feb 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Microwave comes on by itself in middle of night
We have the same problem - auto turn-on, non-functioning keys...
I called Magic Chef and they gave me another number to call:
1-888-775-0202
I called, told the rep about our possessed microwave, and they said someone will be calling to schedule a repair visit. We bought the microwave around May '08 and it is still under warranty.
Call this number and get it fixed. It is a safety problem and Magic Chef should take care of it for you.
Brian
Jul 05, 2008 | Magic Chef CMV1000B Microwave Oven
Refigerator leaked water slightly then stoped cooling
Yes try to turn with a screw driver if possible. If it start working replace timer. If not it can be low on freon you would see frosting but no cooling.
Jan 07, 2008 | Magic Chef CTF2125 Top Freezer...
Magic Chef super capacity range.
oven takes to long to heat, broiler works fine, even the clock works it's just not heating fast....the bottom lights up,but not the top?
Nov 07, 2007 | Magic Chef 31100 Gas Kitchen Range
Turntable not turning
check control circuit, and related spares.
Oct 29, 2007 | Magic Chef MCD1311ST Microwave Oven
Kitchen Ranges Logo
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
